Hi guys
I am looking at buying a aftermarket computer for my R33 skyline?
I have a few mods on the car now like 3.5 inch exhaust from turbo back, hks intercooler, hks boost controler, BLITZ BOV, water sprayers on the intercooler ram pod with heat shield and cold air induction! now I am looking at fine tuning all the mods so far! what do you guys recomend with out busting the bank and goog value for money?
I have herd that Microtec have released a computer which plugs straight into the original loom is this true and how much?
Any feed back would be cool!
https://www.sau.com.au/forums/topic/5033-looking-for-a-aftermarket-ecu/
Originally posted by sidewaymambo
from my own experience, go for Apexi Power FC; consider lots people here have very good experience from it
Power fc is good for upto about 600hp, after that i would b looking at a motec, heck alot of Japenese tuning shops use motec for their drag cars so they r definitally good.
nizmokid,
Best value for money would be the greddy/trust e-manage. It has real time data-logging and has been used on a 1500HP Trust RB26. It has a great deal of tuning abillity. $420 for the unit / $910 for the E-01 boost and hand controller (sell the HKS boost controler this one is better) from nengun.
There are alot of great value products out there, motech is a very expensive one but has class leading resolution. The PFC though quite old now has got some great R&D behind it on the skylines and has a good reputation.
It will probably come down to your tuners choice if you are not technical enough to help. The computer will be only as good as the tune it is given after all.
Originally posted by rev210
nizmokid,
only problem with the thrust e manager is that there isent many tuners around that know how to use the software.
after talking to a few ppl, im buying the microtech,seen as the guy im etting it off has put these in alot of skylines and have worked really well, i wanted to get the wolf because of the features but he said more hassles with the wolf when it comes to idle control or something
Sorry? I don't understand. Do the laws of physics change after 600hp? Do internal combustion engines change from igniting air/fuel mixes to using "liquid hot mag-ma" for this much power?
Please explain how controlling ignition timing and fuel delivery for ANY horsepower figure can't be done by the Power FC.
Cheers.
2rismo,
i think your right there,there shouldnt be a problem with ANY ecu to support more then 600hp.
what can a Motec do that a power fc cant at over 600hp?
what i think can happen is ...dont power fc's use internal MAp sensor?
if so,that might limit the boost pressure,but fitting a aftermarket map sensor should be doable?
Cheers.
The power fc can be used for more than 600hp, i aint saying it cant.!
After 600hp is when u start getting serious, drag racing, track racing, and the motec offers so many more inputs to control other things, Launch control, anti-lag, data logging etc than the power fc doesent!
Serious drag racers in japan even use the Australian Motec system in their cars!
Does this sound like the request of a pro-drag-race type car?
Just my 2c, power fc is plug in, turn key, happy days. tuning from there only makes it better. Idles perfectly straight away, runs all factory gear like a champ.
Cheers
Cheers
my next mod will be a power fc also! :D
dont take what i was saying out of context, just sayin if he was to build a 1000hp motor to go for motec or similiar!:lol:
Originally posted by A31_Cefiro
I think one of the HPI mags had an article on the Microtech CPU for the R33. From what I remeber it sounded like a good setup.
It sure did, & yep it is! But don't bother using one they're crap, as everyone will tell you :D
The Adelaide guys (& a few out of towners) can let you know how my Microtech LT12 equiped GTS25t runs (i.e idle/cruise/all factory features & so on).
This is true cause its new. (sorry didn't mean it to rhyme).
I think it has one of the easiest tuning interfaces to understand and if your tuner is not a knuckle dragger they should have no problem from scratch even if they have never seen it before.
R34 had the emanage recently tuned and got 302rwhp on 0.85bar can't go higher without a Z32AFM.He still has some problems in the timing adjustment due to it being auto essentially its only running in AFC mode!, but trust are helping out apparently). He got 275rwhp out of the Apexi SAFC before switching to the e-manage.
KillerT has the same turbo but has a beefier rebuilt RB25DET with head porting and forgies running 1bar got 305rwhp using the Apexi PFC same dyno I believe.
Thats not a bad effort for the in-expensive emanage given they are almost the same HP.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
    • Literally looks like direct port nitrous haha
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
