I have an 95 r33 auto without abs. When i put the car in reverse and start moving, as soon as I put the brakes on, hard or soft the car clunks somewhere in the front. Can feel it in the steering wheel, could be something in the steering. Im pretty sure my radius rod bushes are stuffed. Any ideas, I down the ocean road most weekends so im pretty worried as to what it is.
James
Everything is tight, so it must be something that is wornout as u have bin suggesting. More recently i have been having to use much more lock to turn when fanging on the ocean road. Not sure if my rear shock are worn out causing that. But is scary to think what could be causing it. If only i could be looking underneath when it does it.
its most probably your bushes, but you should get the same sort of noise in drive too. one way to test is to get some to see if the front wheels move forwards or backwards when braking. just let the car crawl along and apply the brakes a few times.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
