  • Replies 123
Ok guys...I'll give you all a list of whats still for sale....
Most panels, i.e. everything on rear, left side and front
Left door - offers
Right side headlight - cracked at the back so it will need new mounts $50
Rear windscreen and driver side and passenger side windows - offers
Monza rims 17"x9" 2 piece - $700
GTR rear wing and bootlid - $650 for both
Bonnet - Slight damage on right edge: $550
Shocks and springs - offers
Complete Engine and Gearbox ($7500 for both or $8500 if I pull them out of the car)
intercooler - $500
some interior stuff - glovebox, vents, seat belts... etc
Rear diff
Just keep the pms and calls coming for anything I might've missed...
