Hi
Well i said in some threads in discussion to SAFCII's i was getting mine tuned... Well i did today so here are my cars performance mods and the results!
r33 GTS25T 95' Series I.5
T3/T4 HighFlow VL Turbo
GTR Front Mount Intercooler
GTR Fuel Pump
Apexi S-AFCII
GReddy Profec B Boost Controller
3" Exhaust Turbo Back
HighFlow Cat
MegaFlow Muffler Twin 2" Tip
K & N Pod Filter
Blitz Open-Atmosphere BOV
Brass Button Clutch
Locked Diff
9.5" Wide Rear Works Rims
Always run 98 Octane
Stock RB25DET engine.
Stock Headgasket, Injectors
For anyone interested i hope this is enough information to show a power example for these mods and turbo. The tuner said they had a another t3/t4 on another car and it only made the same power on 18 psi, they said they were happy with the result on 12psi and i was too.
Oww i was running Optimax too so once i run Ultimate into it im getting a free Retune in about 2 weeks so we'll see the difference in power there too! BP vs Shell in the ultimate showdown! Bring IT ONNNN!
Cheers,
https://www.sau.com.au/forums/topic/50725-safcii-dyno-tuning-results/
Care to post up your SAFC2 settings?
 Purely for interest's sake?  I'd love to compare them to my tune...
Well depending exactly on how your car runs it'll be tuned accordingly.. i had a quick look... and fuel was leaned out. I cant post up the setting exactly, theres lots of adjustments, + its not like i can do a "Print Screen" sorry.
Cheers,
Very nice result mate! 218kw at the rears is amazing!
Where did you pick up the SAFC-II from? I'm trying to find a cheap outlet.
Came with the car sorry... I would have thought there'd be a few for sale on the 'For Sale' posts when people dictch them for Power FCs. Probably just check Nengun, nismo.com.au, modyourcar.com.au *i think*, and yeh do some searching... Good luck with it.
Cheers,
Thats a pretty impressive gain, you using the stock AFM as well?
I've just fitted one to my stock RB25 with FMIC and pod filter all else stock, I've had a fiddle around with it (small amounts of leaning out) and cant reeaaalllly tell any difference using the "seat-of-pants-o-meter".
I dont wanna muck around with it too much, but i'd like some idea of what ppl's safc's are set to roughly, as far as % correction at what rpm etc? how rich do these things run?
Thanks the sphincter of the universe, remember the Turbo is doing a lot of that gain and not just the SAFCII, they work well with each other. As for tuning, i highly recommend you take it to a dyno tuners... There is lots of little adjustments to get it just right... $250 seems to be a pretty standard rate and they might spend a few hours doing it. You should get a more than happy gain with your current mods, you should really get a boost controller too. I'd get that first, then they'll tune it to your new higher boost! More rwkw! :mad:
Cheers,
good work!! its always good to see results from a tuning session. You'd be surprised the difference fuel makes. Originally had mine tuned on optimax, then switched to Synergy8000, an now runs much better, cleaner, less smell, an more power. From what I hear on both here on the forums and from tuners, so long as you stick with either Synergy or Ultimate your pretty set.
Anyway, good luck with the next tune, keep us posted.
fuel cut defender, adj fuel reg, more boost.....go a long long way :mad:
cheers
Yup mine cost $100 to get tuned. The guy did literally did it in 5 minutes, 1 power run, tweak, another power run, tweak, final power run. Money please!
Kinda dissapointed me in the BFYB terms haha But the gains were solid...
Well i got to test out my new power this afternoon taking it to some good local roads *yesterday was wet* & i was VERY happy with the power... Shit! 3rd is pulling like a mutha f***a :D & theres wheel spin all the way though 2nd now.. yeh she's got some power going now... Might be able to do high 12's but I haven’t been to a drag yet so who knows. Anyway... just letting ya know 218 at the rear is not to shabby to drive at all.. .lots of fun :) and makes drifting that much easier...
Get the SAFC tuned on a dyno, you can even do it yourself, i do. With the stock cooler i was pulling 18% of fuel out at the top end, but with the installation of the FMIC, its now down to about -12% at the top end.
and how did you figure this out? I'm shit scared of making her detonate. My approach was to lean out gradually then swith to the knock monitor, but surely thats dodgy? besides its hard to tell what knock reading is bad, it sits around 40 or 50 normally i think but will sometimes hit 200. I cant wait to get mine on the dyno now, just gotta get new pump in.
  • 4 weeks later...
I am interested to know this standard knock as well...
The only time i get any knock figures showing on the SAFCII is when its warm and idling. It shows upto 5 sometimes...Whatever that means?
Mine got installed and tuned yesterday 194kw's. With FMIC and K&N Pod. On 12psi.
I'm not sure how much its leaning out.
Also, this morning im experiencing problems with idle when cold now. (only since the SAFC was installed).
It doesnt kick the idle up to the 1200 or so that it did when the car is cold. It was struggling to even stay running, spitting and coughing actually.
I couldnt even get it to hold a steady 1100rpm idle by using the accelerator?? It would just peak to 2000 then back to 600...Once it was warm the throttle responded as per normal??
Weird.
Weird.
Hi, the current model of SAFC11 has two throttle position programs, they are programable, but usually set with one for under 70% and one for over 70%. It would seem that your tuner has only tuned for over 70%. If he uses the under 70% range he can tune at the low rpm ranges to fix that problem. This will not affect over 70% throttle settings or high rpm.
Hope that helps:cheers:
Does that also mean that I wont actually notice any difference with fuel consumption?
Cause my last tank of fuel I only got 250kms....(i was heavily strapping it) Plus it smells a little fuely on idle, so i wanted the safc to lean it out so it wasnt soooo rich.
That's what the 2 settings were developed for on the SAFC11's, so you could have power (large throttle openings) and fuel economy (small throttle openings). You couldn't do that with the previous models, you always had to choose one of the other.
Have a talk to your tuner, it is a pretty easy job to tune.:rant:
Im wondering what the majority of Skyline owners have got the air correction set to when on full open throttle?
From what I can tell mine is on 5.
I *think* I have heard that others have got theres on around 10??
Im yet to call the tuners and talk to them about my current problems, I wanted to have a better understanding before I call them. I did download the English manual for the SAFC2 though. Makes a lot more sense than the Jap one I was reading...LOL
Paul
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
