i bought a second hand blitz dual control turbo timer with no instructions.
im trying to install it and i have no idea what im doing.
ive connected a few wires where the timer will now stay on while the key is out of ignition, and it will give me all functions on the display, i just cant get anything to work.
the wires i have connect are from the first plug (2 blacks to earth, green to the red for power, blue to yellow, and red to yellow)
im not sure if they are correct, and i havnt connected any other wires on the 2nd plug (white, purple and orange)
ive spent a number of hours searching the site and other how to guides for the timer, including how to install on other cars but no luck so far.
any help would be fantastic!
https://www.sau.com.au/forums/topic/50812-blitz-turbo-timer-install-on-r33/
hi mate i had the same problem.
i found a site that showed me how to install it ill give you the basics for the colours u need.
Purple --- Hand Brake
Orange --- Speed Sensor
White --- Shift Lock (Auto)
Red --- 12 Volt WHITE/RED
Blue --- Accessory BLUE
Green --- Ign. "on" RED
let me know how you go. the reason why it wont stay on is cause there is a safety feature on the handbrake. if the handbrake it not up then the turbo timer wont stay on. i didnt worry about the speed sensor and the white wire because the only one you need is te purple for handbrake and i also drive a manual so if you drive an auto u may need to connect the white wire.
let me know how you go cause i can email you the instructions that i found off the net. but this is all you need just to connect the handbrake. if u have any problems ask an auto electrician because they know how to install them as well.
Red 12v - white/red
when i connected to the white the starter motor was stuck on lol, so i must have misunderstood something there, and when i connected it to the red the timer did count down with the key in the ignition but when i took the key out it didnt shut itself down at all, just turned off as usual.
my email is [email protected] if you still have the instructions available.
thanks for your help, im sure its only a small thing im doing wrong.
oh, when the purple wire is connected, when it is earthed is that when it thinks the hand brake is 'on'?
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
