Baka Gaijin needs help with kanji tattoo....
Bl4cK32: that IS one kanji - thus can only be written that way
As far as I know, this is the more common kanji -
But both have the exact same reading 'ryuu' (dragon)
Just guessing (I'd have to ask), but perhaps the one you posted is a chinese character that was directly copied (and in use) by the japanese (I personally think the one you posted is more elegant)
the pics you have been posting are modern designs - taking the traditional and given it a 'tribal' makeover - they are relatively common though (and easy for any decent tattoist to do - no shading required, just outline and fill-in)
chinese vs japanese? haha, not my area of expertise - I'd have to ask him. The japanese have a story (maybe it comes from the chinese, I'm not sure) - something along the lines of a carp who swam back up a river and, to climb a waterfall, was changed into a dragon - which is one of the reasons that carp are often used - and often the carp and the dragon are merged (transformation pose)
myself, being a keen fisherman in australia, I could never get a dirty old carp tattooed on me!! :D but I've been trying to think of a way to incorporate a dragon into the side of my oni tattoo (though, to be culturally accurate, it should be a tiger, not a dragon)
okay, re: kanji - apparently the one I posted is a simplified form - somewhere down the line they decided it was easier to make a 10 stroke kanji (as opposed to continually writing a 17 stroke one). This is quite common - having an original ('difficult') kanji, and a later, modified version ('easy')
Cool...so the both mean the same then. I like the tribal tats because of the lack of colours. Relies more on the drawing itself rather than the shading to make the pic....that and the $$ ;)
I think i'll go for the one i posted...as you said more elegant to look at :( Now just gotta arange it some how...
  • 2 months later...
Hey,
Sorry to dredge up an old thread for my question, but I thought it would be more prudent to tack it on here than to start a new thread.
Can anyone offer me an explaination of the below Kanji and what it means, if it even means anything?
I have been told it the characters are pronounced "Rai" + "an". Obviously this is why I'm interested... although I know getting your own name tattooed on yourself is a bit cheesy.
Cheers!
from what remember when I was designing a dragon tat for a freind and talking to the local chinese tattoo artist, if the dragon had whiskers or if it had a forked tongue, it was supposed to be a chinese dragon or something like that... I dunno can someone confirm?
So my name means Dark Thunder in Kanji?
Sweet.
Or is it Thunder Dark which is meaningless?
Also what about "Rai" + "un"?
Well straight direct translation is Thunder Dark (sounds bit like odering a Coffee Black) :) . But u can call yourself Dark Thunder if u want.. :ufo: ..
When u only put these 2 words together Thunder Dark they dont mean much.
"Rai" + "Un" <== are u referring to Chinese pronounciation? They sound similar. In Chinese, the correct pronounciation "Lei" "An" , I think...which doesnt sound close enough to Ryan...i think "Lai" "En" would probably sound closer to Ryan.
ooooh wow tattoos!
i wanna get a tattoo but cant commit for the fear of regretting it later in life...
but if i was to get one, i wouldnt settle for a little thing on my arm or shoulder. i'd go full out and get a huge fcuk-off dragon tattoo that would span the length of my body.
i saw it in a korean movie called "jopog manura" or in english "my wife is a gangster"
in it, there is a scene where the chick (who is a gangster) shows the tat and its a black dragon with iths head starting on the right shoulder, its body running down her back, ass and thighs, and the tail ends just below the back of the legs. i must say its the BEST tattoo i have ever seen. i'll try to get a screen shot here later and when you guys see it, im sure you will agree.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
