well about 9 months ago i hit a gutter in the wet and i had to get a new steering rack and rims. rack cost me $500 +240 to install.. DO NOT GO TO PEDDERS TO GET REPAIRS THEY ARE FARKING DICKH*ADS!!!!. anyway sorry about that.
i had adjustable camber on it and about 2 monts ago i noticed that the bushes were stuffed on it and i replaced the front two with stock ones, front left ball joints, and put in GTR struts with lowered king springs. also i have replaced the thing that connects the upper bush to the hub thinking that was bent but wasn't.
now my problem is that the left side only sits about 1cm higher than the right side.
and when i fitted the upper bushs the left one was a misson to get lined up as the bolt wouldn't line up and we had to bend it a bit to get it to line up. but when doing the right side it was easy as 123. anyone got any idea's on what the problem could be?
thanks guys
https://www.sau.com.au/forums/topic/50967-front-left-higher-than-front-right/
ok measured it up this arvo and the right sits at a normal 360mm and the left sits at a crappy unknown why 382mm. could the sway bar be bend, cos thats pretty much the only thing that i haven't changed??? any help please, otherwise i'll see if the old dud bushs sit right on both sides.
A quick test is to disconnect one of the sway bar links, either side doesn't matter. Pretty ususual to bend a spring steel bar, they just spring back after a hit.
What are the rear measurements? If you have a sagged rear on one side it sticks the diagonal front up in the air.
What are the wheel alignement settings? If it has too much or not enough (uneven) caster you get height differences.
A little more checking, the answer is there, just gotta find the right question. :D
no worries.. i'll get them this arvo and hopefully post them before the weekend. i don't think the rear has moved, its only since i have changed those upper control arm bushes after i hit that gutter.
the rear hasn't sagged at all i can fit 2 fingers in between both wheels on the rear and 4 on the front left and 3 on the front right. i'm going for a wheel alignment on wednesday so i'l get a print out after that if nothing has changed.
  • 2 months later...
ok i just found the book with my 2 lastest specs on it..
BEOFRE
front
LEFT RIGHT
toe in/out +.9 -1.2
Camber -2* -2*
Caster +2 +1.4*
AFTER
LEFT RIGHT
TOE in/out +.5 +.5
got line through
last two figures.
BEFORE
REAR
LEFT RIGHT
toe in/out +.2 +.6
Camber -2* -2*
AFTER
REAR
LEFT RIGHT
+1.2 +1.2
had line through it
again.
thrust angle Before After
-.01* 0
ok sydneykid.. whats the go you reckon?
when i had lowered king springs in the GTS4 front struts then taking them out and putting them into the gtr struts i noticed that the springs were the same height and had the same number of coils on them?? does this mean that the car would sit at standard GTR height?
does anyone know the height difference between lowered GTS-4 springs to GTR springs?? cos if the lowered GTS-4 springs are the same height as the stock ( standard height ) GTR springs and one of them has sagged that would explain why the left side sits up at about standard height.
ANYONE???
bits of string vary in length.
Park your car on a level surface, measure all four corners from centre of the wheel to the guard lip. The from the sills to the deck front and rear both sides.
Now years ago we used to measure glad bags of stuff with two fingers... but the accepted method for measuring a car suspension is tape measure. mm since '74
put the results up here and you may get an answer with some sense...
Good luck
TT
                          BEOFRE
                           front
                     LEFT          RIGHT
toe in/out       +.9           -1.2
Camber          -2*             -2*
Caster            +2            +1.4*
                            AFTER
                    LEFT            RIGHT
TOE in/out      +.5              +.5
                      got line through
                       last two figures.
                        BEFORE
                          REAR
                       LEFT            RIGHT
toe in/out         +.2                +.6
Camber             -2*                -2*
                        AFTER
                         REAR
             LEFT                  RIGHT
               +1.2                  +1.2
                   had line through it
                           again.
                             -.01*           0
The "line through the last two figures" makes it imposssible for me to comment.:(
What happens if you swap sides with them?
I'm pretty sure when I did mine, I just got stuff for the GT-R, and it all fits in.
R32/33 GTR shocks in the Stagea front are OK, but the rear needs R33GTST.
GTR shocks have the spring seats lower down than GTST/GTS4. So the spring heights are not comparable.:(
so what your really saying is that i should buy gtr springs for the front?
Nope, I am not saying that. What I am saying is to buy R32/33 GTR front shocks. I am using the standard springs in mine (both front and rear). With the Whiteline stabiliser bars controlling the roll and the circlip adjustable lower spring platforms on the Bilsteins giving me the right height, I believe the standard springs are the best choice.:(
  • 3 weeks later...
took out the front struts one of them was 2mm lower than the other one. than i changed the shocks to kyb ones with the lowered king springs. didn't change the height but it feels firmer than before.. should i change the swaybar completly with another one and new bushs?
Are you changing the stabiliser bar in an attempt to fix the height difference? Just undo one link, that will tell you if the bar is bent (most unusual) and causing the height difference.
The front heights are 381 (left) and 352 (right), what are the rear heights?
:D
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
