haha this i know:) 1st take out the bottom part of the back seat, unscrew the bolts and pull up the seat- bit treaky just take ya time. then look for the clips holding in the back upright part and pull it out. then you should be able to get to the parcle tray. i think the covers may just come off, but iff not then u may have to unscrew stuff, then the speakers in the pods should unscrew, but if you wana put in 6x9s then you will have to unscrew the whole pod, take out the tray and cut holes for the new speakers. i would use the parcel tray to mark out a new one on thicker mdf, as it will support the speakers better and give better base response!!!
try that and get bak to us:)
https://www.sau.com.au/forums/topic/51301-help-stereo/#findComment-1016332
Installing 6x9's in the back parcel shelf will be a bitch; you will have to cut the metal to fit the speakers in, your better off just popping in some 6 inch splits. once u get the back seat out, there is little room to work on the parcel shelf because of the back windshield, and not much room again to get in from the boot.
https://www.sau.com.au/forums/topic/51301-help-stereo/#findComment-1019248
agreed! I have done those speakers in the rear of a 33. it involved a new parcel shelf AND
removing a FAIR BIT of metal to make them fit. put a decent set of 6.5"speakers in there and leave it.
to get the shelf out you need to remove the rear seat. the instructions above are correct.
with it out the shelf unclips and pulls forward. remove any restraint bolts that may be in the way.
any questions email me.
https://www.sau.com.au/forums/topic/51301-help-stereo/#findComment-1019377
6x9's arent as good as 'normal' good speakers. But if you already have them take comfort in the fact they are good performers for their price.
Whatever you do don't cut metal. God it frightens me how many people butcher their cars. Fit it properly like Craved!!!
Metal cutting is illegal for a reason.. and more importantly because it compromises the structural integrity of the car. You get more flex, it rusts, looks ugly, could possibly end up cutting your head off in an accident, and practically invalidates Nissan's testing of it under pressure/load/crash situations.
Why would you take your car away from the blueprint for something worse?
Jeez.
rant>
https://www.sau.com.au/forums/topic/51301-help-stereo/#findComment-1038300
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
