After 3 engine failures I am finally back on the street with a Skyline - at last.
The R33 GTR is going again, with it's 3rd (& hopefully final engine build)
After the last fiasco just before the last 4,6&rotor nats in Feb (when we made 480rwkw then cracked the block on the friday before the meeting) the street GTR is up & running again.
This time the R33 has a brand new N1 block, new aries forged pistions, smaller 272 HKS cams (the 288 step pro cams from the race GTR are going into a 3 litre that Mark from Rhemac Motors is building for his GTR) & a conservative run in tune
at 1 bar. Tim has tuned the motec at Tilbrooks (who did an excellent job of getting the car ready) & the GTR currently has 375 rwkw (500hp).
The only other change is the gearbox, which is now an OS Giken Sequential 6 speed. This box has bigger dogs then the Holinger & should take the pounding of street use better than the finely tuned Holinger box(which is staying in the race GTR)
I have only started running in the GTR over the last week & hopefully will have it sorted ready for the skyline cruise later this month.
https://www.sau.com.au/forums/topic/51363-3rd-time-lucky/
Hey my Dad used to be the engine builder at Rhemac Motors :D.. he retired about 12 months ago after 20+ years there :D.
https://www.sau.com.au/forums/topic/51363-3rd-time-lucky/#findComment-1017992
good work John, whats the power curve like? also didnt you have a ppg box in their for a little before, did you get a chance to use it much and why the OS 6 speed?
Joel, yeah Tim Possingham now works with tillbooks and has done for a while now, catch up boy
https://www.sau.com.au/forums/topic/51363-3rd-time-lucky/#findComment-1018384
The OS engine is still in the race GTR (which will hopefully be ready before the 4,6&rotor Nats/ & Drag Combat). Yes I did try a PPG box for a little while.
I am testing out the OS 6 speed because I like the sequential changes (& the extra gear)
It sometimes does'nt grab the next gear if not shifted firmly enough - will have to keep practicing.
The power curve is OK for now - is still pretty conservative(I want to get some use out of this engine - not blow it sky high like the previous setup.)
https://www.sau.com.au/forums/topic/51363-3rd-time-lucky/#findComment-1019971
I thought I'd seen the beast tucked away at work a few times lately John. It inspired me to bring mine out for the daily commute a bit more mate! Congrats on being back on the road. Feels good doesn't it?
Tim is a damn fine tuner and I have no doubt that this motor will hold together over the long term. A little less power is much better than another failure! And more money/time.
I'm toying with the idea of going for a bigger turbo on my thing... not sure exactly what yet but 'nicely' into the 300+rwkw region would be the aim. See what happens I guess.
https://www.sau.com.au/forums/topic/51363-3rd-time-lucky/#findComment-1022270
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
