PS2 Pricing
v3 - $149 (neo2 with swap disc - no ar2 req'd)
v4 - Autoboot Messiah $330
- $198 swap version (neo2.2 with swap disc)
v5&6 - $330 Autoboot Messiah
v7 - $330 Autoboot Messiah
XBOX - Enigmah v2 - $199.
PS2 and XBOX chips supply only, subtract 50 bux.
*** NB. These are LOTS different to theold psone chips and are a bitch to chip! Unless you are a soldering god, do not attempt it. ***
Cheers
https://www.sau.com.au/forums/topic/5143-ps1ps2-xbox-chips/#findComment-79409
once more then for the arts students...
To make it easy, post what model ps2 you have (SCPH-3XXX2) and i'll tell you wat it does, how it works and how much it is...
Cheers
https://www.sau.com.au/forums/topic/5143-ps1ps2-xbox-chips/#findComment-80348
Guest GR33DyMANGO
those are pretty good prices for a modchip. ive got my ps2 modded. if your gonna get it done just make sure it plays all formats.. ie CDR and DVDR.. oh yer and DONT get it done at the modshop in belmont. they r e-tarded and they destroyed my first ps2! :( a little bit of yelling helps sometimes :)
https://www.sau.com.au/forums/topic/5143-ps1ps2-xbox-chips/#findComment-86270
can you get your hands on a D.I.Y Internal VCD Card II and a Stealth IV chip for a PSX?
How much for those 2 with no installation... habib rates plz.
https://www.sau.com.au/forums/topic/5143-ps1ps2-xbox-chips/#findComment-90367
    • UPDATE: Yes the GSP Axles are compatible. I installed it on my R34 today and they are working a treat! Turns out that the S13, S14, S15, and 200 SX all used the same axles as the HR34, and ER34 NA models. Which is 2 bolt x 3 pairs.
    • Also build this EH ute with 370z motor and gearbox with a couple of turbos just for fun.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
