PS2 Pricing
v3 - $149 (neo2 with swap disc - no ar2 req'd)
v4 - Autoboot Messiah $330
- $198 swap version (neo2.2 with swap disc)
v5&6 - $330 Autoboot Messiah
v7 - $330 Autoboot Messiah
XBOX - Enigmah v2 - $199.
PS2 and XBOX chips supply only, subtract 50 bux.
*** NB. These are LOTS different to theold psone chips and are a bitch to chip! Unless you are a soldering god, do not attempt it. ***
Cheers
https://www.sau.com.au/forums/topic/5143-ps1ps2-xbox-chips/#findComment-79409
once more then for the arts students...
To make it easy, post what model ps2 you have (SCPH-3XXX2) and i'll tell you wat it does, how it works and how much it is...
Cheers
https://www.sau.com.au/forums/topic/5143-ps1ps2-xbox-chips/#findComment-80348
Guest GR33DyMANGO
those are pretty good prices for a modchip. ive got my ps2 modded. if your gonna get it done just make sure it plays all formats.. ie CDR and DVDR.. oh yer and DONT get it done at the modshop in belmont. they r e-tarded and they destroyed my first ps2! :( a little bit of yelling helps sometimes :)
https://www.sau.com.au/forums/topic/5143-ps1ps2-xbox-chips/#findComment-86270
can you get your hands on a D.I.Y Internal VCD Card II and a Stealth IV chip for a PSX?
How much for those 2 with no installation... habib rates plz.
https://www.sau.com.au/forums/topic/5143-ps1ps2-xbox-chips/#findComment-90367
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
