PARTS MUST GO....
-STANDARD GTR TURBO KIT (turbo’s, manifolds, Dump pipes, etc)
$800 Travelled 30,000km’s GTR R33 Excellent working condition SOLD
-GTR STANDARD CAM GEARS
$50 Excellent condition 30,000km’s GTR R33
-GTR STANDARD BOV’S
$200 Travelled 30,000km’s Excellent Condition GTR R33
-GTR R33 UP PIPES AFTERMARKET (Auto Staff)
$400ono Bolt onto the Dump pipes (size are Twin 2 ½ `` pipes into 3`` Pipe)
-GTR R32 HKS PRIEST EXHAUST (DIFF BACK)
$350 Limited edition exhaust diff back, Excellent Condition
-STANDARD GTR R33 INJECTORS
$400 Travelled 30,000km’s Excellent Working Condition GTR R33 SOLD
-STANDARD GTR R33 FUEL RAIL + FUEL REGULATOR
$200 Travelled 30,000km’s Excellent working Condition
-STANDARD GTR R32 FUEL RAIL + NISMO FUEL REGULATOR SOLD
$250 Excellent Condition
-BLITZ FILTER $200
PM OR REPLY HERE
https://www.sau.com.au/forums/topic/51454-gtr-parts-etc/
Hey guys sorry for the late replies...Been busy... Pics of the Bov will be sent out tomorrow
up pipes can be found here:
http://www.skylinesaustralia.com/forums/at...achmentid=20405
https://www.sau.com.au/forums/topic/51454-gtr-parts-etc/#findComment-1029620
Yeh sure do...Have a look at this link below:
http://www.skylinesaustralia.com/forums/sh...ead.php?t=47262
have a look and let me know
Im after $800firm
https://www.sau.com.au/forums/topic/51454-gtr-parts-etc/#findComment-1046366
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
