Hi,
so now I have all of your attention, I was wondering if I could pick all ya brains on something.
I am buying a r33 gtr, (rb26) and had a compression test done on it and the results were as follows (psi) 105, 105, 105, 110, 125, 110, now the mechanic said that was good.
and as I belive it, it is good as the lowest reading is more than 75% of the highest, but I was wondering if the over all (psi) was to low, ie. I have herd the rb26 is suposed to have 171 psi as a factory fresh motor, if this is the case than is it right that the motor has droped that much compression in (an aparent) 66,000kms.
Im a little parinoid, as Ive never spent sooo! much money!!
any advice would awsome! :P
https://www.sau.com.au/forums/topic/51990-nude-chicks-posing-on-skylines/
Would be better to post what you want but anyway..
The figures sound very low for a RB26 engine. I would suggest up around 150ish to be more in keeping with the mileage.
A cylinder leakage test is better indication of wear plus it gives an idea of where the problems may be by where the air leaks out.
I would suggest taking it to a w/shop experienced in dealing with these type of vehicles .
If your NOR , come to see us, if SOR SST is probably the go. There are other shops but both of us are SAUWA sponsors and try to look after our members.
Cheers
Ken
Mark, I agree with GTRKEN's analysis, but it is also the spread of compression that is important not the actual figure necessarily. Depends how many cranks they allow while doing the comp test. The spread between 125-105 isn't too bad, but as suggested a leak-down test may show more.
Cheers
Paul
Hi there, I bought my r32 gtr august 2003 and it had 108k on the clock. A compression test came back with all 6 cylinders being between high 150's and low 160's. Maybe use this and other peoples info as a comparison :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
