ARghhh :) I want a clutch that will allow me a better ride in peak hour. Currently have a Nismo Twin Plate clutch, and I'm sick of stalling the freaking thing in peak hour (how embarrassing :x )
I'm used to my Toyota Liteace with it's lose clutch, I couldn't stall it if I tried. This Nismo Twin Plate has a "sweet spot" about the size of a pin head :twisted: It's either a delayed take off, a schreech n jerk, or a stall. Not to mention the bunny hopping it likes to do in first.
I might be completely wrong in thinking it's my clutch causing the bunny hopping action, but I just want something that makes me look a fool in peak hour, with less trffic at night and early mornings it's all fine because you can get a nice launch from the lights without the worry of all three lanes infront blocked and a bus infront of you :roll:
Any ideas ? I think I'll need to go cruising with you guys who are a little more technical so I can try and work out whats wrong (prolly just whats between the seat and the steering wheel eh !)
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1240
so jimbo how does it go the car I remember drooling like most of the people on geoffs list over that one. I'd give it a few more weeksb4 changing casue anything else won't handel the power roumour has it that the nismo twin plate is alot easier.
cheers
meggala
any 0-100 times or 1/4 mile times
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1245
It's going as expected. The car is just as I had hoped for, unfortunately I think the driver leaves a lot to be desired :oops: but hopfully this will come with practice. It's not everyday you go from driving a Liteace to a Skyline 8)
At the moment she's looking rather stocky due to taking a lot of things off for the third Tier inspection. However I will be putting everything back over the ext two weeks, and hopefully getting engineers certificates for the most common things that the cops will try and defect me for, just to make my life a little easier.
I thinik I'll leave the clutch, just because I'm prolly copping out blaming the hardware for my failure to understand how to use it together to get the take off I'm after in differing conditions. HopefullyI can get some pointers off you veterans :)
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1246
Prank,
Check out the 6 puk clutch that UAS sells. I've help install one in a GT4 and one in a R32 GTS4.
Both have a really light pedal but have good clamping preasure (about 40% more than standard.
They bite quickish, but very drivable in traffic.
I think they are $595 exchange for the GTS-t's.
J
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1256
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
