ARghhh :) I want a clutch that will allow me a better ride in peak hour. Currently have a Nismo Twin Plate clutch, and I'm sick of stalling the freaking thing in peak hour (how embarrassing :x )
I'm used to my Toyota Liteace with it's lose clutch, I couldn't stall it if I tried. This Nismo Twin Plate has a "sweet spot" about the size of a pin head :twisted: It's either a delayed take off, a schreech n jerk, or a stall. Not to mention the bunny hopping it likes to do in first.
I might be completely wrong in thinking it's my clutch causing the bunny hopping action, but I just want something that makes me look a fool in peak hour, with less trffic at night and early mornings it's all fine because you can get a nice launch from the lights without the worry of all three lanes infront blocked and a bus infront of you :roll:
Any ideas ? I think I'll need to go cruising with you guys who are a little more technical so I can try and work out whats wrong (prolly just whats between the seat and the steering wheel eh !)
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1240
so jimbo how does it go the car I remember drooling like most of the people on geoffs list over that one. I'd give it a few more weeksb4 changing casue anything else won't handel the power roumour has it that the nismo twin plate is alot easier.
cheers
meggala
any 0-100 times or 1/4 mile times
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1245
It's going as expected. The car is just as I had hoped for, unfortunately I think the driver leaves a lot to be desired :oops: but hopfully this will come with practice. It's not everyday you go from driving a Liteace to a Skyline 8)
At the moment she's looking rather stocky due to taking a lot of things off for the third Tier inspection. However I will be putting everything back over the ext two weeks, and hopefully getting engineers certificates for the most common things that the cops will try and defect me for, just to make my life a little easier.
I thinik I'll leave the clutch, just because I'm prolly copping out blaming the hardware for my failure to understand how to use it together to get the take off I'm after in differing conditions. HopefullyI can get some pointers off you veterans :)
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1246
Prank,
Check out the 6 puk clutch that UAS sells. I've help install one in a GT4 and one in a R32 GTS4.
Both have a really light pedal but have good clamping preasure (about 40% more than standard.
They bite quickish, but very drivable in traffic.
I think they are $595 exchange for the GTS-t's.
J
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1256
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
