ARghhh :) I want a clutch that will allow me a better ride in peak hour. Currently have a Nismo Twin Plate clutch, and I'm sick of stalling the freaking thing in peak hour (how embarrassing :x )
I'm used to my Toyota Liteace with it's lose clutch, I couldn't stall it if I tried. This Nismo Twin Plate has a "sweet spot" about the size of a pin head :twisted: It's either a delayed take off, a schreech n jerk, or a stall. Not to mention the bunny hopping it likes to do in first.
I might be completely wrong in thinking it's my clutch causing the bunny hopping action, but I just want something that makes me look a fool in peak hour, with less trffic at night and early mornings it's all fine because you can get a nice launch from the lights without the worry of all three lanes infront blocked and a bus infront of you :roll:
Any ideas ? I think I'll need to go cruising with you guys who are a little more technical so I can try and work out whats wrong (prolly just whats between the seat and the steering wheel eh !)
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1240
so jimbo how does it go the car I remember drooling like most of the people on geoffs list over that one. I'd give it a few more weeksb4 changing casue anything else won't handel the power roumour has it that the nismo twin plate is alot easier.
cheers
meggala
any 0-100 times or 1/4 mile times
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1245
It's going as expected. The car is just as I had hoped for, unfortunately I think the driver leaves a lot to be desired :oops: but hopfully this will come with practice. It's not everyday you go from driving a Liteace to a Skyline 8)
At the moment she's looking rather stocky due to taking a lot of things off for the third Tier inspection. However I will be putting everything back over the ext two weeks, and hopefully getting engineers certificates for the most common things that the cops will try and defect me for, just to make my life a little easier.
I thinik I'll leave the clutch, just because I'm prolly copping out blaming the hardware for my failure to understand how to use it together to get the take off I'm after in differing conditions. HopefullyI can get some pointers off you veterans :)
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1246
Prank,
Check out the 6 puk clutch that UAS sells. I've help install one in a GT4 and one in a R32 GTS4.
Both have a really light pedal but have good clamping preasure (about 40% more than standard.
They bite quickish, but very drivable in traffic.
I think they are $595 exchange for the GTS-t's.
J
https://www.sau.com.au/forums/topic/52-clutches/#findComment-1256
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
