Japan residents post up pics of your 'line! ... or sundry vehicle ;)
  • Replies 125
Heh, nah, I'm referring to a kid in my town who bought a GTS-4 and almost lost it into a tree, then got a WRX believing that fulltime AWD would let him do anything.
He wrote it off with no insurance. :D
Drivetrain not strong? where did you hear this, or you mean compared to the later models.
I have a feeling he's thinking about WRX's and their dodgy gearboxes and the slipping clutch 'safety' method.
I would be sutpid enough to refer the EVO to the REX, i was refering it to the mighty GTR.
West, no offence dude, but AWD isn't the all-powerful problem saving technology that people believe it is. I don't know the situation you got bitten in (hard cornering, tail snapped out?) but AWD cars can break traction just fine, if you push them hard enough
Well no offence and yes i corner HARD and tail snapped out. My 33 does 13,6 on geniune street tyre , if i have an EVO that have the same power at least i'd have got a bit more control that's all. :how:
I can't remember GTR's having horribly dodgy clutches (unless it was caused by abuse), but *shrug*..
Happens to the best of us, but AWD is not going to help you corner hard. In fact, you may find you have more problems because AWD cars are notorious for understeering. You go around a corner, you understeer, you feed more steering into the corner, then oversteer snaps in (and it *will* kick in. the closer to the edge you get, the faster you go over it)... AWD cars are not going to allow you to corner hard or fast. It's a common reason as to why WRX owners end up as small white crosses on the roadside.
If you want to corner hard and fast, spend a metric f uckload on a decent suspension setup, some GOOD, grippy tires (I've got some dunlop LM702's at the momen, $360 a corner, but pretty good, recommended) and then perhaps some high performance driving lessons, where a pro will teach you how to corner fast, safely and effectively. Then you can corner fast, have the fun of a RWD car and not have to work with an understeering awd car.
Technology will not just let you reef the steering wheel and mash the noise pedal and let you live every time. Laws of gravity, inertia and thermodynamics do occasionally have a say in the matter. :D
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
