I've seen the ones whereby it locks the brake together with the clutch pedal......something else for them to cut.....
which means more time involved,keep a wheel clamp in the car just in case,or 4....lock up all four wheels... :)
add that to the alarm siren hooked up to your airhorns......an internal siren to make him to deaf....Autolok the steering wheel.....or remove it if you have a Nardi wheel....I used to do that.....I'm a paranoid kunt :uh-huh:
  • Replies 58
Where do you buy all these security gadgets?
if you use a steering lock (as I do), make sure you install it on the other side of the steering wheel - theives then can't pull it off towards then when they sit in the drivers seat.
I also carry a length of high tensile chain and padlocks, if I am leaving my car for an extended period, I chain it around the rear sub frame and a steel post/telegraph pole. extreme I know, but try to tow that!!!
SICK .. freaking SICK COUNT!
I am now seriously considering a quiktrak this weekend - I would like to know their financial status however.
Me care about my car too, so you got to spend big on your alarm, plus you always do it right the first time. Brant nemesis isnt a bad buy, pretty good alarm system and never had troubles with it. 6 point imoboliser and keypad start.
I however do like the idea of the chain to a pole idea ;)
One of the features he asked for was the Automatic windows. How much does a system cost that when u alarm your car your windows go up by themselves, or do you just have to play around with the wires?
Thx
Apperantly it's not that much more expensive. It's the time it takes your installer to wire the extra wires up from the alarm to the window relays.
$50 ?
There is a small controller device required so that they only go up a certain amount and stop when they have reached the top. Otherwise you could shorten the lifespan of the power window motors.
This controller is actually a very simple logic device with about $5 worth of parts that people sell for 50-80 dollars retail. Plus labour if you dont fit it yourself.
I believe Brandt fit it for about $125. This is another part of the reason i wont buy another brandt alarm.
This use to be available from the UK. I once enquired over several emails about getting this product delivered to my door from the UK and the legal implications.
At the time they were willing to send it in a box labelled "gift" but were unable to give any guarantee's that it would make it past our customs. I didn't end up buying it.
I also can no longer find the homepage for this item. All I can find now is this or similar:
http://www.bow-gun-hunting-sports.com/autotaz.htm
wil..
I guess it comes down to how bad the thief wants your car. If he wants it bad, whats to stop em using those wheel jack thingoes and just rolling your car onto a tip truck.
Any alarm is (as mentionted) just a time factor thing. If you are serious about not losing your car, id see the only way would be a combination of all the above thigs listed.
Im going for the satellite tracking, and.....YER RIGHT! like im telling the whole of the WORLD!!
Serioulsy though, dont leave gauges, hand controllers, steroes in plain sight. Use a club lock (steering or clutch pedal), a high intensity led, an alarm (maybe the paging type if you want to know asap if your cars being toyed with)
Its all about how long they need to get what they want. If its the whole car, bad luck...:D
I can't get insurance and I do care about my car.
Why can't you get insurance? If someone was to blow up your car then no alarm is going to protect it form that. Trackers sound good but if the theft knew what he was doing wouldn't he disarm it? Trackers sound pretty good though I might get one.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
