:rofl:
1994 GTST Skyline
HKS T51R SPL turbo
Custom Tubular stainless manifold
HKS Wastegate
Apexi AVCR Boost Controller
Microtech LT12s
Large FMI
Bilstein Suspension
HKS Springs
3.5in mandrel exhaust
17" Alloy Wheels
New Tyres
Custom Plenum
650cc Injectors
600hp Clutch (new) and lightened billet flywheel
Bosch 044 fuel pump and surge tank
Alpine stereo (amps, speakers, subs etc)
Forged oversized Pistons
Forged RB26 I-Beam rods
Tomei 1.8mm metal head gasket
Replaced all gaskets
Machined Crank
New bottom end and conrod bearings
Price starting at $28,000, but offers are welcome
Yes stupid question, these powers are all ratings not what they will handle or do. Just because the turbo is 1000hp doesn't mean it will do that by simply bolting on! With the clutch how it is, it is holding all that it is given to the extreme - no slip at all!
At 1.5bar it is making 305rwkw at the tread, which is roughly 410-430hp (roughly), so what I am saying is that if anyone wanted to buy this car and do any more POWER out of it, then you have a fair bit of room to go for the clutch to start slipping. It is a NPC clutch, which uses a nissan patrol turbo pressure plate (mega clamping force) and is currently allready running on 600hp supra that runs down the quarter quiet regular.
The specs of the turbo are a T4 Split pulse flange, .90 rear housing with a .72 polished front cover. It is a HKS T51R, which is stamped on the rear housing. The manifold that it attaches to is a custom Japanese built tubular stainless steel manifold. The wastegate comes off the manifold in a split pulse style way and straight onto the road for the ultimate scream!
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
