Is there any advantage to get the D-Jetro version instead of the plain jane stuff? I know I can go toss the AFM's out with MAP sensors with the D-Jetro. The car is still running the stock pair of turbo.
The only thing I can see is, I can go sell my Z32 AFM's to recoup the money spent on the PowerFC D-Jetro.
Thanks.
https://www.sau.com.au/forums/topic/52435-powerfc-vs-powerfc-d-jetro/
Wouldn't bother.
Unless you are chasing obscene amounts of power where the 90mm Q45 infinity AFM's are too small, keep the AFM's and just buy the normal PowerFC.
Why buck the system. Many more people can tune them with AFMs.
In my case I wish I got a D-Jetro instead of the normal Power FC. Apparently my combination of cams, turbos & custom intake resulted in "pulsing" of air through the AFMs making the car undriveable on light throttle settings (2 volt swings on the afms). This never would have presented a problem with a D-Jetro although my case is probably a more uncommon problem.
Like I've said before, the only reason was, it only cost slightly more for the D-Jetro AND the MAP sensor kit and at the end, I could ditch my Z32 AFM and sell it which works out to be cheaper than buying the normal kit.
slapper - how difficult was it to tune your car may I ask? How long did it took?
go_nuts - the tuner is having to make up a balance pipe between the 2 afms which he is doing next week, it will go back for a second attempt at tuning then, will keep you posted. In hindsight, the cost & wasted time with the Power FC was not worth it, I should have gone a Motec M600.
We have some wild GTRs running Wolf plug ins with no MAP sensor problems so the D-j PFC will be fine. Do you have a compressor surge problem or have you removed the factory BOVs?
Steve, its a rapid succession of chuff-chuff type noises coming out the compressor side of the turbos that only happens on light throttle - it is running a GReddy Type R BOV that is vented to the atmosphere.
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
