I though I would start a thread for Stagea dyno graphs. Before you ask, no this one is not mine, it came from a Mercury Motorpsort dyno day. Note the A/F ratios richen up the higher engine rpm, no wonder the fuel consumption goes though the roof when you give it some. As far as I know this Stagea has exhaust mods.
https://www.sau.com.au/forums/topic/52540-stagea-dyno-results/
here's my graph, 195awhp, and damn i'd swear the octane boost and shell optimax was really giving a few more horsies up untill that f#%*&@n bus got in front of me.
no matter, hopefully i'll get a good settlement, enough for the KING.....260! :Paranoid:
Damn, I was hoping that Stageas didn't have the annoying RB25DET power dip around 5,000 rpm when you give them a mild tune. :zap:
Took it down the quarter at Willowbank 2nite. Got a 15.55 @ 143km/h in AWD and a 16.03 @ 138km/h in RWD. Let my brother have a go too, he got a 15.77 @ 141km/h in AWD.
No problems at all running in RWD apart from traction of course.
Edit: Did raise some eyebrowes though doing a bit of a burnout :P
Yep, stalled the Auto up to just a little bit of positive pressure on the boost gauge, it outlaunched a 300ZX and he didn't take me until about 50m before the 400m mark. I kept it in 2 but didn't hold it in 1 because I don't seem to be getting much of an advantage, just hits the rev limiter too much. I also hit the rev limiter around 120km/h in 2nd because I changed a tad late, so could prob get it to 15.4 or so, on a cold night maybe low 15s?
Have a look at the timeslips (left one is AWD vs. 300ZX Turbo, right one is RWD vs a rather quick S15) The other pic is my bro staging vs. a Corolla Twincam, I don't think he stalled it up far enough because he got bogged a bit and only took the Corolla around the 660ft mark, that's where he ran a 15.77. The Rolla got a 16.something.
Just noticed this thread, you used my dyno sheet from thedyno day at Mercury. I was having a boost problem too. Had the Profec B installed incorrectly and it was only making 6 psi. There you go that is essentially standard apart from exhaust and being manual.
Have got plans in place to change those figures substantially. :elaugh: :elaugh: :elaugh:
hey guys, heres a dyno chart from the other day. this is for a fairly stock example, with standard cooler / exhaust, and 10 psi boost. cheers!
Woooo, that's very lean. Have I read this right, all you have done is just turn the boost up? Nothing else?:D
gary1, thats on a rwd dyno. and sorry forgot to add mods......10psi, pod filter.
should try the rwd only dyno run on my car and see how much power loss there is.
Jay,
32 GTR fuel pump is a straight bolt in and yes it does make a difference. Fuel tank has the same part number.
Cheers
Gary
Finaly got the car tuned with the SAFC in and it went from 180 HP at the rear wheels to 231 HP running 12 pounds which is a good tune by the guys at SST but it was running rich as so the tune will help with the economy.
Blitz Front mount, Blitz Exhaust, Dual SBC, Turbo timer,
Apexi Pod Filter, SAFC, Usual guages.
Was this auto or man. If auto, how does the SAFC go?
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
