I like to be secretive... *chuckle*
Ok, OK I'll just post it.... even though it was much more fun pretending I was popular getting PM's...
I'm asking around the $500 mark for the pair of seats.
From what I know standard Skyline seats are intgerated into their rails. It's not hard to remove the seats and get to the rails and they can be put together and used again later but the seats are not functional without the rails.
The seats are unused and were intended to be put into an RX7 series II before my mate traded it for a Mirage, but that's another story.
they have four bolt holes on the bottom to which you bolt them to the rails. If you look at the Skyline seats they are a similar arrangement (from memory as I've only seen the seats once) but due to the backrest being integrated into the raise/tilt design you must remove this whole assembly and make up brackets from scratch. Which wouldn't be too hard if you have any metalworking skills and equipment.
If you want to cut the standard seat apart then the standard mounting holes could be used with the tilt and height adjustment mechanism being retained. this may make the seat a little high though....
That's about the limit of my small knowledge. :)
https://www.sau.com.au/forums/topic/5257-sports-seats/#findComment-82981
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
