Hi all RB20 fans. I wish to let others aware that TURBO'S are not always the go. I have RB20 with tripple Webers feeding it. My own design and it works well. Is putting 120kw at rear wheels. Not much you say but is fine by me. I am after a set of RB20 Extractors , tuned if possible, but not for turbo unit. Can anyone help? I also wish to install a RB25 de head and all accessories and was wondering if it does fit without dramas to a RB20. Again any assistance would be greatly appreciated. Regards RAY
https://www.sau.com.au/forums/topic/52594-rb20/
Hi Ray,
welcome to SAU! good to see some more C110 owners joining up!
i have been doing a bit of research into putting RB25's into the C110 (as that is my plan for my GTR replica), from what i have read (there is bits about it in the thread about the RB30 bottom end conversion in this thread http://www.skylinesaustralia.com/forums/sh...ead.php?t=15420) but i have to warn you it is a very long thread!!! try looking at one of the members, joels signature, look at the pfd document he has created, it discusses it a little in there.
you need to do some extensive work to get the RB20 head to fit onto the RB30 bottom end, the RB25 head fits up to the rb30 bottom with very minimal modification (R32 RB25DE needs none, R33 RB25DE with VCT needs mods to the VCT oil feed).. so therefore you would need to do some extensive work to get the rb25 head onto the rb20 bottom..(i think the water and oil galleries do not line up)
is there a reason you want to go with the RB25 head? the only thing i can think of is the larger inlet/exhaust ports.. but it would be damn expensive (just in the mods alone, let alone the cost of the head) just to do it for that, maybe goto an RB25 bottom too (though it sort of subtracts from the whole GTR thing)
as for the tuned headers, try placing an add in the wanted section, you might get lucky!
would love to see some pics of your car, especially the engine bay!! did you do the conversion yourself?
Kent
https://www.sau.com.au/forums/topic/52594-rb20/#findComment-1035388
Hi/ Thanks for the reply. Yes I have done all the conversion with the motor. However my 2 door is a KPGC110 (1973) not common to these shores with 4 wheel discs. rear deck spoiler, flares and all the goodies. Has been completely rebuilt over the last 2 years. I could send you photo's, however I am new to this and am unsure how to do it. I also for your help if you have a 2 door, of the 240K body shape then I have ALL manuals in English and Japanese on disc and book form. I have been collecting for 22 years.
You may wish to contact via email That is okay. What part of the world do you reside? I am in Brisbane,
Regards RAY
https://www.sau.com.au/forums/topic/52594-rb20/#findComment-1035529
mp3 - sound file.
What Adam is saying (in normal, non computer techno geek talk) is:
"Cool. That must sound sweet. I would love to hear the Weber/RB20 setup at full song :) :headbang: :uh-huh:
I too would love to see your rig. I've got a 2 door 240k, which currently has a P76 V8 engine in there. (Sacrilege, you may say, but I'm kinda attracted to the old Skool feel of the old pushrodosaurus). The car's not a goer at the moment, as it's my long term project.
I found a wrecker down the Gold Coast who claims to have about 10 240K's in his yard. I'll try to find his number and get back to you.
Oh yeah, manual on Disk would be very sweet (unless you have a spare hard copy you'd be happy to part with)
https://www.sau.com.au/forums/topic/52594-rb20/#findComment-1035560
Hi Let me know your address and I will burn and send one off to you. I have seen this car on the net. Is/was a bit rough when I first saw it. Mine is externally shape the same but a lot of cosmetics that are different Whats your email and I will forward some photo's of it
Regards RAY
mp3 - sound file.
"Cool. That must sound sweet. I would love to hear the Weber/RB20 setup at full song :P  :headbang:  :uh-huh:
https://www.sau.com.au/forums/topic/52594-rb20/#findComment-1039080
hahaha you're too diplomatic. Mine's rough as guts at the moment. No need to hold back - I just bought it a few months ago, so you won't offend me if you tell me you think it looks like a pile of pus (which it does :rofl: )
I just scored a full efi setup for the V8 the other day, and am planning to build a programmable ECU for it. That'll keep me out of trouble for a while.
My email is [email protected]
When you send the photos of your car, I'll email you my postal address, so you can post the disk. Thanks again for the offer.
https://www.sau.com.au/forums/topic/52594-rb20/#findComment-1039611
Hi okay then what is the best way to increase SOME power I am not fitting a Turbo. I am trying to locate a set of extractors for the RB20 Hard to find. Not even built still from my sources in Japan. Ray
You don't want to fit a RB25 head on the RB20 block - you'll lose a heap of compression, not to mention that the bore size of the RB20 is considerably bigger than the RB20 bore size (86 vs 78).
https://www.sau.com.au/forums/topic/52594-rb20/#findComment-1043375
I understand N/As really need longer duration cams than turbos, which probably means custom grind. Or you could try RB20DE or RB25DE camshafts.
Port the head.
Shave a few thou off the head to raise the C/R. Fit domed pistons.
https://www.sau.com.au/forums/topic/52594-rb20/#findComment-1043544
G'day Ray. Thanks for the photos :rolleyes:
If you want extractors, just get a set of custom ones made, to suit the driving you plan on doing (ie rev range). if you shop around, you might be surprised how cheap it can be. There's an exhaust shop at Slacks Creek who do work for a great price, but I don't know how good they are at designing perfromance exhausts (have not dealt with them personally).
I believe that a well designed custom system will be better than an off the shelf system every time, as you build it for your specific needs and engine tune.
Hope this helps
Peter
https://www.sau.com.au/forums/topic/52594-rb20/#findComment-1046400
[ Yes I have tried a few and the cost is staggering. $900, Although I wish for tuned length I am endeavouring to get modified cams and upgade a few other bits. RayQUOTE=warps]G'day Ray. Thanks for the photos :P
Hope this helps
Peter
https://www.sau.com.au/forums/topic/52594-rb20/#findComment-1047537
something like these would be what u want .. pretty sure thats a Rb20DE ..or maybe 25 .. anyways ...same difference ..
R31house in japan i think made these .. dont quote me ..just assuming that coz the photo was on their website. ..so the headers suit R31 ..so somethingl ike that would easy fit into your car i would think.
the latter 3 pics are of a rb30 de with solex carbies i think .. or maybe something else...
Matt
Enjoy
https://www.sau.com.au/forums/topic/52594-rb20/#findComment-1051262
Hi Ray, im also new to this forum, i noticed that you mentioned you have manuals etc on cd for the 240k. I own a c110 240k sedan and would be very interested in obtaning a copy from you if its not too much trouble - i will reimburse you for your trouble. Hope to hear from you, regards,
Tom
https://www.sau.com.au/forums/topic/52594-rb20/#findComment-1052517
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
