I am gonna put a Sub in the boot, but dont wanna pull interior apart as once u pull it apart once it never goes back 100% , so i was thinkin maybe run cables in flexi conduit and run the conduit under car from engine bay then up through the boot where there is a plug, this may sound stupid but i dont see why it wouldnt work?
https://www.sau.com.au/forums/topic/52654-running-cables-under-car/
i got my subs professionally installed. The guy did the subs, amp and all the wiring for $70. Did a fantastic job, pulled the car apart but put it together 100%. Doesnt even look like anything was touched.
If your worried about ripping up your insides then get it installed by a pro... running them under the car doesnt seem like a good idea but could work
lol... if you think $70 is steep then go to Strathfield, those guys wanted $140 just for the cable installation. For $70 everything got installed, neat and tidy and everything looks immaculate... the amp was mounted on the back a sub box and all the wires in the boot are concealed... there's no way i could do a job that good... very happy with the job
installation took about 2 hours with some diccussions... the cables set me back $30 (79.95 at strathfield). 600Watts RMS 4 channel wiring kit... enough for both my 600Watt subs no hassels. The sound is clear and no distorsion from the subs whatsoever (cant say the same for my stock 6*9's which will be going soon)
So anyway... j, if you are worried bout damaging your carpet from the wiring, a pro at a decent price is worth every cent in my opinion
$70 sounds extremely steep just for somebody to run a cable through.. However if you want it done perfectly without damage, get a pro to do it, if they damage anything get them to repair/ pay for the damage.
__________________
thats about what I charge for a 2 channel amp EXLCUDING the power kit. $130 with wiring included is the norm
I do this everyday and never had a probelm with panels ( on r31,32,33,34) not going back on right.
if you are in doubt get it done professionally. it will save you the cost of broken panels and trashed harnesses ( if you pinch one when you put the seatbelts back in!) and everyone of us in the business has insurance to cover a f'up IF we make one.
cabling under a car isn't a good idea. RCA cables arent made for outdoors and wont last anymore than 6 months tops. powercable is a similar thing unless its double jacketed.
  • 4 weeks later...
I wouldnt even walk into a strathfield, let alone leave my car with them and pay them to touch it.
When I was 18 and had my first car I had one install done by them, just amp connection and cable supply as mentioned above, was $140 and i redid it all myself properly within a month. Never again. I should thank them I guess, seeing how badly "professionals" did it gave me the confidence to do it myself for the first time and i have never looked back.
if its against the guidelines then mods just remove the link.
if your looking for good advice on installing stuff yourself then have a look at www.caraudioaustralia.com there is some good tutorials in the forums.
yep a lot of the kids I trained there had no idea. most still don't...
CAA is a good starting point. a better one is asking a lot of questions and trying yourself.
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
