  • Replies 61
Bah, 1st gear burnouts are for PU$$Y'S!!!!
:flamed:
:werd:
Hell my old datto 1600 used to do burnouts with both wheels in 3rd gear....even managed one in 4th! (only once tho....cooked the clutch)
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOW
Sit right back and you'll hear a tale,
A tale of a fateful trip!
That started at the Yatala BP,
They went cruising for a bit!
Now the stright went on and on and on,
Through the cane fields,
and then when the corner came up,
the rubber started too peel!
The brakes were locked the passenger scared
the driver parying to stop.
But did you think it stopping in time,
OF COURSE NOT!
So there were about a million 'lines,
All gasping at the horror,
Of one sad looking skyline,
beached apon this island!
There was Gilligan (Ska)
The Skipper too (chaos)
The millionare (krawler)
and his wife (NismoGirl)
The move star (strutto)
The proffessor (Nexus9)
and Mary-Anne (owned)
HERE ON GILLIGANS ISLE!
:rofl::D :D :rofl: :rofl: :rofl:
I wish andrew was a millionaire :(
I think we all do , I could just see him rocking up to a cruise in his new Lambo with 2 sets of new rear tires in the back and putting on a show of how to do 4th gear B/O
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
