R32 GTR test drive
Originally posted by GTRKING
Does he STILL have the silver one with all the mods?
If so he has had that car for more than a year now!!!
and has used it on the track numerous times.
LOL... About 6 months ago I was going past Phillip and that silver R32 GTR pull out of the car yard and he gave it a bit. Then when he saw me putting along in my GTS-t he gave it heaps, and I mean HEAPS.
Now I'm not sure if it was cold or what, but the amount of black smoke that came out of the exhaust was amazing. It looked like the Batmobile there was so much smoke!!!!
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-81817
all gtr's either 32, 33, or 34 blow black smoke when hammering (i know i own one) the rb26 motor u could say is similar to a rotary engine by that i mean they love to rev the more it revs the more it burns oil thus u get the black smoke out the back, it's normal u just gotta check the oil and change it regularly.:D
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-82129
Whytry,
Well I'd have to disagree with you on this. I have owned
a 97 33 GTR-V for 2 1/2 years and currently drive a 92 32
GTR and in all the time I have owned them neither blew
copious amounts of black smoke under load and by that
I mean dancing on the red line. especially the 33.
Neither were heavily modified thou! and when you
start playing with the computers etc they tend to
run pretty rich to protect the engine this adds to the
black smoke "stealth" effect :D
ohh and if your oil is cold any car will blow weed! but
I do know that the silver 32 in phillip is a heavy smoker
all the time!!!
R,
Adrian
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-82138
nope mine is red with gold rims just got it back on road after 6 months in workshop getting 'mods' has at moment QLD rego but i'm changing it to N.S.W. rego soon after i 'run' in motor, it's an r32 gtr.
was out and about tuesday night and last night, around civic, woden and manuka.
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-83067
nah that gunmetal one is mine, i only drive it to uni,so thats why its always on william slim. Hey Goran how you goin im the guy that rang bout the power FC. You car is so sweat i wnat you to take me for a drive when jake has it all finished off. He is doin some stuff on mine after some disapointing dyno results that were no were near where they should be we should catch up some time!!
Daniel
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-83373
hey daniel
yeah for sure i'll take you for a spin, i'm just waiting for the hand controller to come in.
yeah jake was telling me he too was dissapointed in the results, but that ok till you get it sorted out properly and hell when u do man that thing WILL absolutely haul some serious butt.
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-83452
Guest thedriver
neergnevets -
Well I got into a R32 GTR and let me tell you.. they are small and tight.... obviously designed for Japanese in mind...a lot smaller than my Mx6.
The R33 is a lot bigger and roomier inside. Even the more open dash plan makes it feel larger. This seems like it was taking into account they may be exported to the rest of the world.
So it's back to the R33 for me... will have to save some more!
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-87275
I sold my MX-6 yesterday! I had to drive it to the buyers
house, so I went straight form the GTR (32) to the Mazda.
I honestly didn't think that their was that much difference? I guess if you've got a sunroof in the MX-6 open you could stick
ya head out!!! :)
Is anyone interested in a track day?
https://www.sau.com.au/forums/topic/5268-r32-gtr-test-drive/#findComment-87315
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
