Hi All,
I'm looking at getting my R34 GTT lowered and don't really know where to take it or which springs to get?
I've had my R34 about 6 weeks and I've just joined SAUWA. Any advice or ideas would be greatly appreciated. I'm hoping to get it lowered and cleaned up for PAS.
Also, one of my rims is a bit scratched and I was hoping to get em all polished. Anyone know where to go and how much it would cost?
Cheers,
Jarred
https://www.sau.com.au/forums/topic/52772-lowering-r34/
Here is the link to the place most SAUWA guys go for rim repair:D
http://www.skylinesaustralia.com/forums/sh...ight=rims+fixed
Lowering it, I'd just go with King Springs, the stock suspension is good, just a bit high. Can get you a price tommorow if you'd like:D
Cheers
Paul
https://www.sau.com.au/forums/topic/52772-lowering-r34/#findComment-1037725
Lowing it, I'd just go with King Springs, the stock suspension is good, just a bit high. Can get you a price tommorow if you'd like:D
Cheers
Paul
Thanks Paul,
Would love a price! Any ideas on where/price to get rims polished?
P.S. What was the link?
Cheers,
Jarred
https://www.sau.com.au/forums/topic/52772-lowering-r34/#findComment-1037736
Hey Erik,
Yeah, though you might have - I've already met you! I came and looked at your black one when it was on carsales.com too!!
I heard you sold it - How's your new ride? I should be on a cruise soon (or might eben make it to dyno comp on weekend) - Looking forward to meeting everyone and seeing some other awesome rides.
Nice ride dude, Saw that car on sale on carsales.com.au 2 months ago , Hope to see you on the next cruise :)
https://www.sau.com.au/forums/topic/52772-lowering-r34/#findComment-1044157
HI Scags,
Oh really? Hehehe I didn't know that btw how's your ride? :) fast? :D
It's auto right? if I'm not mistaken
Yeah it is hell fast - well compared to my previous ride. It IS auto which is a bit unfortunate. That was one of the things I liked better about yours, also yours was lower - but that will be fixed soon :D It has the sports mode on the steering wheel, so that is some compensation. I may look into changing the transmission eventually, but I don't know if that is an impossible (or too costly) task?
It has some really nice mods though and they are all high quality. The car is in near new condition too.
Where did you get your new yellow R34? What needs to be done to it before you put it in PAS?
Cheers,
Jarred
https://www.sau.com.au/forums/topic/52772-lowering-r34/#findComment-1044270
Hi scags, got msn?
Nah my ride is slow due to tuning and no ebc atm :)
Mine was super super low :D , just get lowered springs or coil over and you will be fine.
Your ride is nice, everything is perfect except the rims :D, I'm getting impul front bar as well :D kekek
Everything is good? icic that's good then
I got my ride from NSW, I just don't have time man kekeke :rofl: I just need to repair rims and exterior which is easy but due to money and time I just won't put it in PAS this year
btw my msn is [email protected]
https://www.sau.com.au/forums/topic/52772-lowering-r34/#findComment-1044272
  • 5 months later...
Here are some photos so you can see how bad the height is right now!! It's like a monter truck!
The Rims are 18" (8" wide at front and 9" wide at rear) The tires are 35 profile.
The gap to the guard is thicker than the tires :cheers:
Cheers,
Scags
Hi there.
Got a question, is that a factory bodykit or....?
Looks great! :wassup:
Thanks
https://www.sau.com.au/forums/topic/52772-lowering-r34/#findComment-1270347
Hi there.
Thanks
Hi Merlin,
Nah - I don't think it's factory - most R34's I've seen don't have that kit. I don't know where it is from, it was on the car when I bought it. I think it is called a Bomex body kit?
P.S. The 34 looks heaps better now that she's lowered
https://www.sau.com.au/forums/topic/52772-lowering-r34/#findComment-1271098
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
