Hi All,
I'm looking at getting my R34 GTT lowered and don't really know where to take it or which springs to get?
I've had my R34 about 6 weeks and I've just joined SAUWA. Any advice or ideas would be greatly appreciated. I'm hoping to get it lowered and cleaned up for PAS.
Also, one of my rims is a bit scratched and I was hoping to get em all polished. Anyone know where to go and how much it would cost?
Cheers,
Jarred
https://www.sau.com.au/forums/topic/52772-lowering-r34/
Here is the link to the place most SAUWA guys go for rim repair:D
http://www.skylinesaustralia.com/forums/sh...ight=rims+fixed
Lowering it, I'd just go with King Springs, the stock suspension is good, just a bit high. Can get you a price tommorow if you'd like:D
Cheers
Paul
https://www.sau.com.au/forums/topic/52772-lowering-r34/#findComment-1037725
Lowing it, I'd just go with King Springs, the stock suspension is good, just a bit high. Can get you a price tommorow if you'd like:D
Cheers
Paul
Thanks Paul,
Would love a price! Any ideas on where/price to get rims polished?
P.S. What was the link?
Cheers,
Jarred
https://www.sau.com.au/forums/topic/52772-lowering-r34/#findComment-1037736
Hey Erik,
Yeah, though you might have - I've already met you! I came and looked at your black one when it was on carsales.com too!!
I heard you sold it - How's your new ride? I should be on a cruise soon (or might eben make it to dyno comp on weekend) - Looking forward to meeting everyone and seeing some other awesome rides.
Nice ride dude, Saw that car on sale on carsales.com.au 2 months ago , Hope to see you on the next cruise :)
https://www.sau.com.au/forums/topic/52772-lowering-r34/#findComment-1044157
HI Scags,
Oh really? Hehehe I didn't know that btw how's your ride? :) fast? :D
It's auto right? if I'm not mistaken
Yeah it is hell fast - well compared to my previous ride. It IS auto which is a bit unfortunate. That was one of the things I liked better about yours, also yours was lower - but that will be fixed soon :D It has the sports mode on the steering wheel, so that is some compensation. I may look into changing the transmission eventually, but I don't know if that is an impossible (or too costly) task?
It has some really nice mods though and they are all high quality. The car is in near new condition too.
Where did you get your new yellow R34? What needs to be done to it before you put it in PAS?
Cheers,
Jarred
https://www.sau.com.au/forums/topic/52772-lowering-r34/#findComment-1044270
Hi scags, got msn?
Nah my ride is slow due to tuning and no ebc atm :)
Mine was super super low :D , just get lowered springs or coil over and you will be fine.
Your ride is nice, everything is perfect except the rims :D, I'm getting impul front bar as well :D kekek
Everything is good? icic that's good then
I got my ride from NSW, I just don't have time man kekeke :rofl: I just need to repair rims and exterior which is easy but due to money and time I just won't put it in PAS this year
btw my msn is [email protected]
https://www.sau.com.au/forums/topic/52772-lowering-r34/#findComment-1044272
  • 5 months later...
Here are some photos so you can see how bad the height is right now!! It's like a monter truck!
The Rims are 18" (8" wide at front and 9" wide at rear) The tires are 35 profile.
The gap to the guard is thicker than the tires :cheers:
Cheers,
Scags
Hi there.
Got a question, is that a factory bodykit or....?
Looks great! :wassup:
Thanks
https://www.sau.com.au/forums/topic/52772-lowering-r34/#findComment-1270347
Hi there.
Thanks
Hi Merlin,
Nah - I don't think it's factory - most R34's I've seen don't have that kit. I don't know where it is from, it was on the car when I bought it. I think it is called a Bomex body kit?
P.S. The 34 looks heaps better now that she's lowered
https://www.sau.com.au/forums/topic/52772-lowering-r34/#findComment-1271098
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
