Gday Folks, I attended the cruise and i can only say one thing, what an utter waste of police resources.... sending 5 cars and 6 officers out to Newton to try and defect as many cars as possible (yes they did say that :D ), for over 2 hours. I for one am shocked and amazed at the actions of these officers, and would encourage anyone who came on the cruise to complain in all appropriate channels:
The Police cars in attendance were:
XQD 555
XQD 093
XQD 363
XQE 377
WQX 371
The Officers at the scene were: (only managed to get 1 name, but all numbers)
1964 (did not reveal name when asked politely .... i thought this was legal requirement if asked??)
4690
7244
8812
1817
2159
And the channels for complaint:
SA Police:
[email protected]
Ph: 08 8207 5000
The Australian:
http://www.theaustralian.news.com.au/secti...55ETEXT,00.html
The Advertiser:
http://www.theadvertiser.news.com.au/secti...s^^TEXT,00.html
The ABC:
http://www.abc.net.au/contact/
A Current Affair:
P.O. Box 9
North Adelaide SA 5006
Ph: (08) 8267 0298
http://aca.ninemsn.com.au/storyidea/story_ideas.asp
Today Tonight:
http://seven.com.au/todaytonight/contact_suggest
Again, Feel free to bombard the appropriate channels with complaints/suggestions.... practice your right to free speech!
This is also going up on Ausrotary, Toymods, and Nissansilvia.com, so feel free to put it up on any other forum you think of
Cheers
Robbo
https://www.sau.com.au/forums/topic/52791-cruise-oct-8th/#findComment-1043286
Yeah, its no good..... :D Lucky i wasn't driving... was with a mate in an r31 and another in a soarer, they didn't get done, but i saw numerous imports receive a defect and overheard one officer accuse the owner of a (from what i could see) stock r33 gtr of doing 'burnouts'.... even after he explained that it would be hard to do in a 4wd car :)
ridiculous, simply ridiculous and completely unjustified is all i can say... i really do hope a lot of people put in some complaints...
https://www.sau.com.au/forums/topic/52791-cruise-oct-8th/#findComment-1043293
yeah I didn't get done - the officer was quite polite to me and told me I had a really nice car :D
Total waste of resources though - I hope everyone writes an email to the approriate people - I know I will!
https://www.sau.com.au/forums/topic/52791-cruise-oct-8th/#findComment-1043483
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
