damn it!!
I've just found out my next car is not going to arrive in australia until about mid-November :D so not going to be on the road until at least the end of November, if not a little bit later.
I think I'm suffering major cases of turbo withdrawal!! I keep seeing turbo cars around here the pshtt sounds so good.. and can't stand it anymore :rofl:
I've got most of the parts to turbo the r31, but unfortunately I think I may have *kind of* completely hammered the drivetrain and need to replace the unis and crap on the tailshaft.. Whole car is vibrating like a bitch... No idea how that happened :Paranoid:
What can I do?? Just how can I counter this serious case of turbo withdrawal for another month? Humourous Suggestions? ...
https://www.sau.com.au/forums/topic/52918-withdrawal/
buy a cheap old volvo...y'know the ones that whistle because of bad aerodynamics
err.. that's the r31 :-s its got really *cool* vibration now too. ..gives your arms a good workout whilst driving..
And you can also give me that RB30 block of yours
well you can look at it :rofl: but not touch.. touching is an extra $100...
When you come to work I will let you look longenly out the window at my car, hell if your sales are good for the day I may even let you sit in the passenger seat if you like
well i could always pay the kids over the school a couple of bucks to throw rocks at it again.. that could be good for a laugh :D
https://www.sau.com.au/forums/topic/52918-withdrawal/#findComment-1039777
well i could always pay the kids over the school a couple of bucks to throw rocks at it again.. that could be good for a laugh :rofl:
HAHAHAHAHAHAHahahahahahhhaaaaaaaaaaaaaaaa that's golden I love it :flamed:
https://www.sau.com.au/forums/topic/52918-withdrawal/#findComment-1039794
not as funny as the time I got the courier to pretend that he had backed into your car ten minutes before they new owner came to pick it up..... that was really good for a laugh, in fact I still chuckle to myself whenever I remember the look on your face...........priceless :(
and they were throwing rocks at Rob's car not mine, thats why he has been getting it painted :)
https://www.sau.com.au/forums/topic/52918-withdrawal/#findComment-1039807
its in japan.. and its a car in japan :)
damn colour blind kids ! I said hit the GREY car they GREY CAR.. and looks like they aimed for the green instead... good for nothing kids.. I gave them candy as well.. umart is after all "just a stones throw" from the school there :(
https://www.sau.com.au/forums/topic/52918-withdrawal/#findComment-1039838
sorry, eNgLiSh nO gOod, pLeaSe tO StOp KitTy pOrn, hEre iS wHY :whackit:
http://cats.about.com/gi/dynamic/offsite.h...Fkittyporn.html
aNd
http://cats.about.com/gi/dynamic/offsite.h...ittyporn.org%2F
aNd iF u wAnT 2 sLeEp wElL aT NigHT
http://rotten.com/
:headshot:
https://www.sau.com.au/forums/topic/52918-withdrawal/#findComment-1040786
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
