if any one has the 100v 2 pin plug in there stagea ...hullo prank...i have this interesting piece of kit that came in the back of the 260 but i think the guy has taken inverter with him
its a kenwood super woofer...looks like a smoke machine or some kind of rocket launcher
3 switches on back ..phase(norm or rev),omni position,turnover
3 lights ,60/90/120 hz
volume dial
on the front just says 100v 35w 50-60hz
is a heavy mofo ..really don`t know what it is worth ...can anyone tell me??
https://www.sau.com.au/forums/topic/52950-100v-inverter/
Jake, that looks a lot (if not exactly) like a HOME subwoofer that Kenwood released many moons ago, IIRC...
Maybe it's an added bonus from the last owner when the car was sold and sent from Japan!?!?!
Couldn't tell you what it was worth, though, sorry. Maybe you could get the model/part number off it and Google it, and then have a look on e-bay as well.
Nick T.
https://www.sau.com.au/forums/topic/52950-100v-inverter/#findComment-1041462
Nick T.
yeah its a sinister looking piece of gear...i`m thinking i could get good money if i listed it on e-bay IRAQ.....with the right ammo it could take out tank...
https://www.sau.com.au/forums/topic/52950-100v-inverter/#findComment-1043076
i have option catalog ..DAYZ...piture of rear power point in console with laptop /keyboard plugged in to it ..scanner has issues so cannot post pic atm
i know where there is a sic subwoofer that will run of it and i suppose any jap 100v equipment
will also
https://www.sau.com.au/forums/topic/52950-100v-inverter/#findComment-1044081
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
