  • Replies 176
Those are the boards we use for the S14 and work well.
Expensive when bought in small amounts so the group buy will be a good thing.
How is this going and how many more do we need to sell for a cheap price.
We may get a few to help with price purchase. Have you got the address table yet?
Cheers
Ken
Yeah, these boards work in a few cars.
I bought them from Grid Japan and will be contacting them about a discount once I have got mine in the car and working so that you guys won't have a board doing nothing.
Have not had time to pull the BIN file from my car yet :(
ecl,
The main benefits on a stock 34 will be the ability to raise the boost cut threshold, remove the speed limiter, and retune the factory maps to suit australian fuel and conditions, typical gains on standard boost just with tuning are around 10 rwkw.
Doc.
  • 3 weeks later...
  • 1 month later...
I am interested but need more info on the tuning as I don't know if anyone in Cairns could tune it and would a control handpiece like the Power FC be needed?
Sorry about my ignorance but this is all new to me.
My Stagea is currently standard but soon due a 3inch turbo back exhaust. FMIC and Turbo upgrade.
Hi guys,
Sorry for the late reply.
Finally managed to pull the ROM file from the stock ECU (thanks 666DAN & also DUMHEAD from silviansw.com).
Now all we need is the address file for the rom or try to crack it.
Yes this board will, according to GRiD Japan, work with S14/15/ER34(RWD, 25T)/U12/C34.
I do not have the rom files for the S14/15/U12/C34 though.
I've attached the ER34 manual BIN file I pulled from the stock ECU.
Ed,
Will you still be able to get me one of these? I can help out in locating the address maps. However it is going to be impossible unless we have different binary files to compare with.
Try extracting the Auto one and see the difference. Fuel maps should diff?
Ben, do you have a laptop with 9 pin serial?
The cable needs 9 pin serial to work.
Then we can pull the 34 GTT auto maps.
Give me a buzz.
Ricky, I've put up the manual map's. See if you can crack it ;)
So far when I apply the ECR33 address table to the 34 BIN the only thing that is the same is the rev limiter.
7050 rpm.
the badbiki daughterboard pictured wont work with other R33/R34 (non ER34) ecus which have a Hitachi H8 chip. these need a special daughterboard which houses the H8 chip and decoder circuitry.
i am able to disassemble and create address files from binary images (things like K constant, RPM and speed cuts if not in the rom editor ADR files are a bit more tricky but not impossible)
that one posted i see maps around 1200- 2800. the VQ is 1200-127F
what is the main chip number on the ER34 ecu? ie what type of CPU
yikes that was quick. yeah i need the numbers (top row) on the big chip of the ecu to do the disassembly. you can see on the second pic there are a row of holes which you solder the daughterboard to
I knew there had to be a good reason why I was stock-piling these bloody R34 ECU's :D
OK the big chip says: LM702D01J
Pretty sure that's it, as it's hard to read
Other printed lines read-
A12-212 750
816B100
the A12 number is the JECS identifcation code. the bottom number would be serial number
the top one. LM = manufacturer code of which there are about 20 listed for LM on chipdir. i think it is probably Hitachi as most Nissan ecus are but could be anything. SR20 ecus are badged JECS but are Mitsubishi chips for example
how accurate are those digits? i know they get hard to read. best with magnifying class under fluro light at some wierd angle to read the writing properly. at worst wont if i cant get it disassembled wont get constants (rpm, k const, speed limit) only tables/maps from doing a rom compare
I'm 99% sure....I did grab the fluoro and magnifying glass :rofl:
The chip also has that "UJ" logo that's in the centre of the circuit board printed on it.
Whoops just figured it...Unisia Jecs! So it's a Hitachi chip
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
