Hey Guys
My rear right suspension has developed a knock :)
It will knock several times when going around a corner with one or more people sitting in the back. What is causing this?
dont be too descriptive now, thats a pretty basic question without much info :O
heavy passengers???
Edited by CruiseLiner
haha Yeah sorry - Had to dash off to work!
Well it used to be able to hold all the weight I wanted. This is only a recent problem... Hitting the bump stops possibly? Now if this is the case - I dont want to sound like too much of a Noob (even though I am) what do I have to do to stop it? New shocks? Suspension?
All this thinking has made me tired...
what suspension u got now? stock or lowered? sk's kit?
does it sound like a metal on metal sound, or rubber on metal?
bumpstops are a very ... well... bumpy ordeal when they hit.
I have a kinda knock, id call it a crack (like a screw) from the rear and I know its because of the rear wheel bearings + high km's + being lowered.
my "knock" occurs when the suspension is traveling, aka around tight corners etc (dont hear it in the sweepers)
Well disaster has struck my car yet again.
It's been at my suspension mechanic for 2 weeks now, and i'm not getting it back anytime soon. Wheel bearings have been a pain in the butt to get replaced, the set he thought would work were 1mm out and even a 15T press couldn't get them in. He got the right ones, but they won't arrive until monday.
My suspension mech being the good bloke he is loaned me his 350Z for the weekend, but i turned him down. no way was i going to drive around in one of those, i'd be paranoid of hitting something.
Every time he looked under the car he noticed the CV boots splitting all over the shop, so i'm up for 4 of those now. a word of advise: DON'T USE UNIVERSAL CV BOOTS. they aren't designed for the movements the driveshafts make on stageas and wear in weak points and split very easily.
On the up side, i now have straight as an arrow rear wheels. no more negative camber. i'll get part numbers for those adjustable arms so everyone can share in my straightness. means i can lower the car a little more now without worrying about uneven tyre wear, or even tyres rubbing on my coilovers (which is was presently doing)
the knock sound you are hearing could possibly be the rim itself rubbing on the shock body, i have had this problem in the past with independant rears and being lowered.
remove one of the rear wheels and check the inner lip of the rim for damage, also look on the shock body itself for rub marks of any kind.
would be keen to get a hold of those part numbers as soon as they are available!! so i too can have straight rears but i have a series2 so would you be able to compare for fitment? as i have never seen another stag on the road its bit hard to compare stuff.
Rubber on metal id say... Really loud bump bump bump bump noise..... and pretty bumpy. Its kinda like someone bashing the car with a metal pole.... would that be the bump stops?
I have some more noobish questions for you all...
1. When you have the wheel of the car deadstraight - the car is actually turning slightly to the right (just had an alignment about 5 weeks ago... need another?)
2. When braking heavily... and sometimes just driving along, the whole front end of the car shudders very violently. Especially through the steering wheel. What could that be?
My car still isn't fixed. my mech sourced 4 wheel bearings through nissan, and they only sent him 3. this is a disaster, i hope no one else has to go through this much pain to replace wheel bearings. this will cost me a fortune, but hopefully my car will run super smooth and quiet.
Wheel bearings...... I have NEVER EVER replaced wheel bearings on a Skyline, they are monsters. I have seen cars with 300,000 k's still with good, original wheel bearings. Are you sure the problem was wheel bearings?
1. Hit anything recently? Are you sure it's not camber of the road, so that water runs into the gutter? Did they set it up with more caster on the left than the right? This helps to offset the road camber problem.
2. Sounds like warped brake rotors, have you had the run out checked lately?
:( cheers :(
Edited by Sydneykid
Yeah i'm sure it's the wheel bearings. they're shagged completely, making terrible noise and such. i've done almost 170,000km on my stagea. only 2 of them were busted, but i figured i'd replace all of them at the same time.
my odometer might not be accurate either with all the clocks being wound back (got it at 97,000)
So I was looking at buying 'Low' King Springs for R33 GTS-T (Supposed to lower the Skyline by ~30mm). And I was aware they might be too light for the Stagea, so I looked to see what Nismo sold for rear of both cars in terms of weight.
Rear Springs Only: Stagea (lowers 20mm) 4.4kg/mm, R33 GTS-T (lowers 20mm) 4.8kg/mm
So the Skyline springs are heavier which isn't what I expected. I know different cars can have different Motion Ratio's from the recent Autospeed article (http://autospeed.drive.com.au/cms/A_2904/article.html), but these cars would be the same I would expect (sharing the suspension and all).
So why shouldn't I buy the R33 Kings....? Are they gonna lower the Stagea 30mm as specified for a Skyline, or more, or less? I'm thinking more..
have a set of r33 gtr super lows which drop the gtr by 40mm. spring rate is 180lbs/in with was going to be OK based on previous calculation advise... these are for the front and from different peoples advise ( suspension shops) they have said that it would be OK although bit rough
for sale now.. never got on the car still in wrapping
going the group buy set up
OK, I’m confused.
You can’t use R33GTST rear springs in a Stagea, they don’t fit. The Stagea has smaller strut towers, presumably to give more load space. Plus Stagea rear springs are linear rate, not progressive.
Front springs wise, R33GTR physically fit and would be the closest in rate.
:wave: cheers :)
OK, I’m confused.
:dry: cheers :D
Confusion on my part too then, I thought R33GTS-T rear springs fitted the rear of a Stagea. Stagea ones are tapered at the top right? I see from a pic that R33 rears are too.
So if the Skyline rears don't fit (just talking fit here, not rate suitability), what do?
Cheers.
The geometry of the Stagea rear end is different. The cross member is definitely wider and the drive shafts are longer. I wouldn’t be surprised if the fulcrum points in the rear suspension are different therefore giving different leverage on the springs than in an R33 therefore the different spring rates.
The springs that fit are SK’s secret. You will have to ask him of buy them from him.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
