All you vic slackarses that don't check the rest of the forum who wanna join team superfunhappysliders, you can get your free email forwarding addy's "[email protected]"
so if you want one post up:
alias wanted: eg: something
forward to: eg:monkeh at skylinesaustralia dot com
https://www.sau.com.au/forums/topic/53089-superfunhappysliders-email-addys/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
