how much beating could it handle?? i mean would it withstand a moded RB26??
and how much does it run for a clean one??
You would have to do the usual mods to it, plus a large cooler. They are a genetic Jatco, they supply to lots of Japanese car makers. I have seen similar internals do an 8 in a 2.5 litre WRX, with nitrous and all the usual stuff.
There are a few auto to manual Stagea conversions going on, so you should pick one up realatively cheaply. Post up a wanted and see what sort of response you get. :)
https://www.sau.com.au/forums/topic/53101-rb26dett-auto/#findComment-1044052
Save your time, and PM me. I've got one left over from the RB25DET upgrade to the R32 GTS4.
https://www.sau.com.au/forums/topic/53101-rb26dett-auto/#findComment-1044082
And your point ? Look at GTR700 and HKS R33 and a lot of other skylines in Japan that run 8 so were both even.
Plus manual is more fun :)
The only advantage with auto is that you will get constant quarter mile runs but you will eventually have problems with it slipping out of gear not working properly etc.(stock auto box) but if you have that much money to spend why dont you buy me a 8 second Skyline ? :jester:
Manual is more of a challenge by trying to get a potential 8 second skyline down the strip can be a handful. Ovbiously your not up for a real challenge thinking that putting a GTR engine in a Gtst with an auto box is.
If your aim is to build an 8 sec GTS-T i hope it goes well, but if you think you have one of the quickest car in Cairns by owning a 300kw GTR and saying theirs no challenges up here you'r dreaming. I dont believe it intil i see it ;)
-----and what is rong with running the engine stoc puting out 300 rwhp----- ?
Read what you said before that.
-----and not sure on my hp to rwkw conversion but isnt 390hp less than the R33
GTS-T puts out stock standard-----
:D
Jun
https://www.sau.com.au/forums/topic/53101-rb26dett-auto/#findComment-1050149
Hi guys, as most will know I am not an auto fan, they simply don't work in a circuit race car. But if I had to build a sub 10sec drag Skyline I could do it with an auto far easier and far cheaper than a manual. Hugos will sell me, almost off the shelf, an auto capable of running 9's all day for less than $3K. A manual gearbox capable of the same will cost three times that, then add $3K more for the clutch. The auto is going to be much softer on stuff like tailshafts, diffs, driveshafts, uni joints etc. The standard stuff that will survive with an auto, won't with a manual.
Some examples......
FIRNA protechnik
64 Vette - 10.1
RaceGLIDE Transmission
Leigh Rainbird
V8 LH Torana - 10.9 at 123mph
RaceGLIDE Transmission and Comp Shifter
Frank Marchese
V8 SB Ford Super Street XA Falcon - 10.7 at 125mph
Turbo Charged 6 Cyl Holden - 9.80 @ 143mph
Race MATIC Transmission
Omar Sedmak
V8 SB Chev Naturally Aspirated Ford Cortina - 9.50 @ 140mph
Zak Weir
9.50 @ 140mph
Steve Athans
8.45 @ 167mph Twin Turbo
Craig Thompson
Blown Rodeck Chev 8.30 @ 166mph
Craig Brewer
468 BB Chev
8.70 @ 153mph
Mark Clifford - HG Holden
10.1-355 Holden and RaceGLIDE
11.0-331 Holden and RaceMATIC
Warren Appleby
9.60 @ 143mph
Richard Caval
9.90 Index
Tony Diviak
10.4 @ 128mph
Scott Fitzpatrick
8.61 @ 158mph
Andrew Seager
Blown BBC Rodek
7.4 @ 178mph
Omar Sedmak
9.90 Index Racing
Michael Konstandinou
ICE Ignitions
Naturally Aspirated 6cyl 265 Hemi
10.4 @ 126mph
Simon Pimm
Turbo 6cyl
9.4 @ 138mph
Lee Bektash
308 Holden 8.99 @ 151mph
Alistair Palmer
9.90 Index
https://www.sau.com.au/forums/topic/53101-rb26dett-auto/#findComment-1050489
Guest two.06l
Some examples......
FIRNA protechnik
64 Vette - 10.1
Leigh Rainbird
Frank Marchese
Omar Sedmak
Zak Weir
9.50 @ 140mph
Steve Athans
Craig Thompson
Craig Brewer
468 BB Chev
8.70 @ 153mph
Warren Appleby
9.60 @ 143mph
Richard Caval
9.90 Index
Tony Diviak
10.4 @ 128mph
Scott Fitzpatrick
8.61 @ 158mph
Andrew Seager
Blown BBC Rodek
7.4 @ 178mph
Omar Sedmak
9.90 Index Racing
ICE Ignitions
10.4 @ 126mph
Simon Pimm
Turbo 6cyl
9.4 @ 138mph
Lee Bektash
Alistair Palmer
9.90 Index
add mick stanic to that list
powerglide in a 4wd gtr!!!!!!
https://www.sau.com.au/forums/topic/53101-rb26dett-auto/#findComment-1050516
The current issue of Zoom mag has the beginning stages of putting an RB26 into a 4 door R33 backed by a modified factory AUTO.
The workshop that modded the auto, M V automatics, claimed it will handle the power fine and also not be un street friendly with over the top harsh shifting.
And it wasnt an expensive excercise either, under $500 is what it cost to beef the auto.
https://www.sau.com.au/forums/topic/53101-rb26dett-auto/#findComment-1050608
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
