Your so right, who gives a rats arse if its fair or not, just do as you are told, good boy - appathetic attitudes really piss me off - maybe you should become a cop, you seem to think that they are right regardless.
Fact - the SA POL DO NOT ENFORCE THE LAW, WITH REGARDS TO THE ROAD TRAFFIC ACT CORRECTLY,
Fact - TPT SA DO NOT ENFORCE VEHICLE STANDARDS CORRECTLY.
I have had enough of these forums
Take care all.
All the Road Traffic Act and Road Traffic Regulations say with regard to ride height is it has to meet ADRs and have a minimum 100mm clearance. How is that wrong or harsh?
  • Replies 50
Take care all.
OOOOK......................
Hey, this is reality and they are the RULES and regulations that govern this state. If you dont like it, do your little bid to fight their bullshit like you attempted to last time. Me personally, Ill do my best to keep my cars 'looking' legal. And the one that doesnt, ill just play the game of staying away. There are more serious matters in life to be whinging about defects on an obviously defective car. By the way, how did your little fight against TSA end up again????? :talk2hand
Then there's the 1/3 of suspension travel, then there's the minimum height your headlights must sit... If they don't get you on one thing they will get you on another *when they want to*.
Adam,
I actually hav'nt looked at the reg's for sa. however i do know that a 100mm block is passed under your car at a regency pk inspection and cannot foul anthing under your car-eg:exhaust, handbrake cables, electrical cables or suspension components etc..
Regards,
SKYLINE(Kym).....
Adam,
      Regards,
                  SKYLINE(Kym).....
When did I say it wasn't 100mm? I've said it is twice! It can foul under the car on a few things though
Ground clearance
 73. (1) In this rule:
"ground clearance", of a vehicle, means the minimum distance to the ground from a point on the underside of the vehicle, except a point on a tyre, wheel, wheel hub, brake backing plate or flexible mudguard or mudflap of the vehicle.
 (2) A motor vehicle or combination must have a ground clearance of:
(a)at least 100 millimetres at any point within 1 metre of an axle; and
(b)at least one‑thirtieth of the distance between the centres of adjacent axles at the midpoint between them; and
©at any other point—at least the distance that allows the vehicle or combination to pass over a peak in the road with a gradient on either side of 1:15, if the wheels of 1 axle of the vehicle or combination are on the slope on one side of the peak and the wheels of the next axle are on the slope on the other side.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
