spotted andy at the peanut at midway shops today, i was also in a volvo (government bus) so im surprised you didnt see me too :down:
I luv the sleek lines of the new model. Just the way those corners fold is aero dynamic efficiency at it's finest. LOL
May I wask, what is the peanut? :P
the seats arent too bad considering trim. however, sharing it with 59 other people is the worst bit............
Hmmmm seats are gross in public transport, I remember reading the lab test results from a few old train seats that were tested, you don't want to know what was on them. Or probably easier to say there was not much that wasn't on them :|
the new seats are fabric, but yeah i dont touch them with my hands lol
heheh, you don't have to.
You sit in them, then carry all that crap into your home, sit around on the couch/bed etc... not to get you paranoid at all.
Germs are good for strengthening the immune system :P
btw, love the new avatar :down:
(you really need some white LEDs in those parkers though)
just spotted andy and craig outside my house. guys, piss off youre freaking my neighbours, they are worried too many volvo drivers are moving in :P
LOL.....
P.S Whats with you and the old lady next door...... I saw you check out the her arse after flirting with her!!!! Does she have an M35 you want parts off!!! :)
my car lives in a garage and i hardly drive it now. i kinda live in denistone east which is why you never see me in eastwood. too many shitty drivers lol
spotted on bruce hway(freeway)at burpengary,at 2.20 pm,very tidy series 2(i think) black stag..(couldnt flash, highway patrol car in the vicinity) :P
I was pretty pleased to see 2 stageas today! first one was a silver s1 seen on Albany Hwy just before carousel, we both gave the thumbs up and went our different paths. The other was a s2, also silver, nice rims too. saw him on roe hwy, followed on the freeway till gehw exit. it not to often i see them, glad that i did today :happy:
