Light blue or dark blue M35?
Where?
ah it was a darker blue and i think it was on the Nepean highway near Mentone area... i think can't remember now
Always nice to see a fellow stag owner n give a wave :P we're like motorcyclist
Spotted a whole heap of M35's at the Stagea meet tonight.
Thanks for the venue Jetwreck.
you didnt mention spotting a blue fiat 500. i feel a bit left out!
Not to mention that awesome dark green s1 C34!
I am sure you would have felt left out turning up to a Stagea meet in Fiat.....LOL
Bloody weirdo - 'sif blame it on the wife for needing the Stagea to transport a bunch of her friends into the city or what-not...
nah i didnt, mostly because i had the best handling car there. ohh and most fuel efficient. and i could beat craig on a take off too :thumbsup:
'sif best handling, too...
Are you telling me that your Fiat is faster than a Mazda 121....... Wow.
LOL!!!
i had some fun in the traffic on the way home from work today with a WRX, the fiat is VERY nimble and in traffic its probably the best car ive owned for traffic thrashing
Now hat is just Blasphemy.....LOL
spotted in currimundi on sunshine coast dark red m35 arx. steve is the owner, pulled over to have a chat.He will have a look on this site. dead keen for more info on his pride and joy. :)
I forgot to mention that on Tuesday night I spotted a dark (not sure what colour, noticed it at the last minute, and it was dark) C34 Stagea on Greystanes Road in Greystanes - it was around 7.30pm-ish.
u were about 2 cars back from the roundabout in the right lane headed from dural, and
i was coming from county drive going across-ways into shepherds drive going into cherrybrook.
i went thru pretty quick as it was sorta pissing down
Spotted Silver M35 RX (XCF799) on Whitehorse Road heading from Box Hill eastwards. I was behind him in mine then pulled up beside him in before he turned off towards Blackburn. Honked the horn, he looked but no real response. Not sure if it would be anyone on here?? Asian fella...
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
