3S GTE would be nice, but they came in Celica GT4's and there's not many wrecks of em in AU. The one in the Caldina's what I'd probably use tho.
I'll be trying to make the car as fun as possible on a budget, which means avoiding getting parts from Japan and trying to get habib rates from wreckers in Australia wherever possible.
I could use the engine from the AU Corolla Sportivo, VVTL-i 2ZZ-GE. Expensive as its a newer engine. But nice N/A power and its available locally.
But the easiest thing to do would be to get a 4AG-ZE (even tho it was never sold in AU) usually in jap wreckers for about $500, chuck a set of HKS or TRD cams, or perhaps maybe if luck's on my side, get a 5A stroker kit from HKS.
I will be researching it a lot more... in the meantime I'm gonna concentrate on gettin the car back to roadworthy state and maybe start restoring the interior and planning my finances to see what I can afford to do and what not to before my imagination gets the better of me.
Till then I'll drool over my copy of Option2 May 1997... Hachi Roku special (with complete instructions on how to maintain/update the AE86's).
hey funkymonkey,
my mate just bought himself an aus-spec 86 also but it has a 4AGE in it goes pretty hard and with its exhuast sounds like something out of initial d ;)
I love those car, i am thing project 86 also when i get some cash :rofl:
good luck, keep it N/a and drift it :)
riiiiight... ;)
so??
read the whole thread first...;)
Funky, if you really want to go with a 4AGZE and the AW11 one's given their age maybe not be thin on the ground, you can always use one out of a AE92 but they are also E-W...will also need work but are newer.
My mechanic here has a sweet 86 which you may have seen in the Japan thread. Though you have said you will try not to source from Japan, if you need any stuff or advise you know who to call. He's the one who has Grp A internals...basically a race engine....but currently out after killing it a few months back at Central circuit.
if a 5A kit comes up at the jap wreckers I use or at yahoo auctions and its under a grand, then I'll snap it up.
I'm prepared to spend up to 6 grand on the car excluding all the costs incurred so far to buy the car and chuck it on a truck to melb.
Nice one troy... I might pop up to japan next year sometime, might come have a lil chat with you guys (u n rezzeh). But yeah, thanks for that tip, I've done an engine swap in my old toyota sera (turbo engine from a turbo starlet) but that was a very easy straight forward swap. Since then I sold that car n bought a 180sx "ichi-go", and then the R32 n now this ;)
not coming for TAS?...else come to the Osaka Automesse in Feb.
My mechanic sold his BNR32 for the 86, the GT-R he also killed at Central circuit LOL. Though he misses his GT-R his 86 is no short of fun...makes me want to buy one too.
I'd personally save the money, keep it NA with the 4AG and have fun revving the tits off it.
Have you done one and from which 3S? out of a Caldina or MR2?...never said it was not possible...everything is possible. It is the time, effort and COST involved in converting a 3SG to RWD and finding out that there is very little gain when you could have just turboed the 4AG or Beams 3SG!
I know a few guys in Aust have done it but ask around here and the J-guys will tell you why bother!
finding a wrecked altezza is hard enough, let alone a Beams 3SG. Also I'll have the R32 for turbo fun. I'd like to keep the "Gaijin 86" N/A or supercharged for constant response (because I'll most probably try to learn how to drift in it, so I want soemthign predictable).
    • Wheel alignment immediately. Not "when I get around to it". And further to what Duncan said - you cannot just put camber arms on and shorten them. You will introduce bump steer far in excess of what the car had with stock arms. You need adjustable tension arms and they need to be shortened also. The simplest approach is to shorten them the same % as the stock ones. This will not be correct or optimal, but it will be better than any other guess. The correct way to set the lengths of both arms is to use a properly built/set up bump steer gauge and trial and error the adjustments until you hit the camber you need and want and have minimum bump steer in the range of motion that the wheel is expected to travel. And what Duncan said about toe is also very true. And you cannot change the camber arm without also affecting toe. So when you have adjustable arms on the back of a Skyline, the car either needs to go to a talented wheel aligner (not your local tyre shop dropout), or you need to be able to do this stuff yourself at home. Guess which approach I have taken? I have built my own gear for camber, toe and bump steer measurement and I do all this on the flattest bit of concrete I have, with some shims under the tyres on one side to level the car.
    • Thought I would get some advice from others on this situation.    Relevant info: R33 GTS25t Link G4x ECU Walbro 255LPH w/ OEM FP Relay (No relay mod) Scenario: I accidentally messed up my old AVS S5 (rev.1) at the start of the year and the cars been immobilised. Also the siren BBU has completely failed; so I decided to upgrade it.  I got a newer AVS S5 (rev.2?) installed on Friday. The guy removed the old one and its immobilisers. Tried to start it; the car cranks but doesnt start.  The new one was installed and all the alarm functions seem to be working as they should; still wouldn't start Went to bed; got up on Friday morning and decided to have a look into the no start problem. Found the car completely dead.  Charged the battery; plugged it back in and found the brake lights were stuck on.  Unplugging the brake pedal switch the lights turn off. Plug it back in and theyre stuck on again. I tested the switch (continuity test and resistance); all looks good (0-1kohm).  On talking to AVS; found its because of the rubber stopper on the brake pedal; sure enough the middle of it is missing so have ordered a new one. One of those wear items; which was confusing what was going on However when I try unplugging the STOP Light fuses (under the dash and under the hood) the brake light still stays on. Should those fuses not cut the brake light circuit?  I then checked the ECU; FP Speed Error.  Testing the pump again; I can hear the relay clicking every time I switch it to ON. I unplugged the pump and put the multimeter across the plug. No continuity; im seeing 0.6V (ECU signal?) and when it switches the relay I think its like 20mA or 200mA). Not seeing 12.4V / 7-9A. As far as I know; the Fuel Pump was wired through one of the immobiliser relays on the old alarm.  He pulled some thick gauged harness out with the old alarm wiring; which looks to me like it was to bridge connections into the immobilisers? Before it got immobilised it was running just fine.  Im at a loss to why the FP is getting no voltage; I thought maybe the FP was faulty (even though I havent even done 50km on the new pump) but no voltage at the harness plug.  Questions: Could it be he didnt reconnect the fuel pump when testing it after the old alarm removal (before installing the new alarm)?  Is this a case of bridging to the brake lights instead of the fuel pump circuit? It's a bit beyond me as I dont do a lot with electrical; so have tried my best to diagnose what I think seems to make sense.  Seeking advice if theres for sure an issue with the alarm install to get him back here; or if I do infact, need an auto electrician to diagnose it.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
