Poor 32. Lucky it broke down where we were. Otherwise I think we could have been in the shit :P
Thanks HEAPS to Melv for coming and rescuing us! :hugs:
And thanks HEAPS to Mick for following us home to make sure that we made it :(
hahahahahaha yeah melv had just a little prob finding us lol
Ah I Can See You Just Can't Get To You lmao :looney: round & round we go that place was a maze :spcartman
no probs erin any time :angel: I know any of the gys would do the same for me :grouphug:
just a quick update.. turns out to be loose wiring, so thats easy fix.. now just need to wait for ecu tuning. :P
oh and honda city is cool! bring on the city turbo I say! :D
hahahaha there is a soft top turbo up the coast for sale 85 modle for 6k :looney:
that would be cool but thats just a crazy price :bonk: little 1000 lt rocks :(
I know why my car is so fuely ... Well, even more fuely and gutless than normal :(
Alternator is shagged. 12v maximum during running, and 11.buggerall volts once you turn lights on.
If you just turn the lights on, the voltage drops from 12.buggerall to 10.something fairly quickly... Is that a battery problem? Or is the battery only partially charged cause the alternator isnt doing anything? Even with revs (2500-3000rpm) it wont charge the battery at all, just holds a constant 12.3'ish volts.
Piece of crap. I'm with will :P Gimme the little buzzbox back :D
Glad to hear it's only something small Will.
I might ring Gav and ask him why he didn't answer my phone call at 11pm last night.
LoL, other than the sleep thing and all :(
Good to hear it was only a loose wire tho. I think, does that mean your not stripping it anymore? :P
if the alternator belt isn't slipping or overtightening, and measured idle voltage at alternator/battery not showing 13+ volts then alternator is gooooooonnnnnnneeeeeee. :(
dave you can still strip my ful sik subwoofa tape deck?! :(
hmm so does that mean next time I got pick up my pos 32 it'll sport a sohc head with a ded commie battery and sits on bricks? :D:( godamn bogans! :P
RB26ETT for Willis :D
Who needs to D(ouble overhead cams)?
Hmm... RB26 head on RB30 block....
Oh well, I'm sorta glad there is something fairly big wrong in a way... It makes a good excuse for the lousy performance and huge amounts of fuel smoke :D "Oh yeah mate, normally I got 800hp but damn alternator was shagged so I only had 100hp" :P
Now I'm not a mechanic... (Unlike some :S ) But I'm gunna disagree on this one...
Cause... The spark doesn't burn the fuel... The spark starts the fuel burning (I thought) and then the flame front ignites the rest of the charge...
So, tiny spark may not be perfect, but it will either ignite, or miss... Not just burn some of the fuel and spit the rest out...
Also, with low voltage, the injectors wouldn't be opening up as much anyway, so there would be less fuel than usual... (depending on ECU (the car does have EFI doesn't it Andrew :cheers:))
I'm guessing timing and / or fuel pressure and / or tune...
/awaits proof of my stupidity...
Dunno the technical side of it, but with Brutis2, when the alternator died and started giving low voltage he would run REAL fuely.
Then as the voltage dropped lower, he would misfire. Finally, car died totally.
Either way, the alternator is shagged. 12.2v at big rpm in neutral with no lights etc on isnt right. And 11.7v with the lights on also isnt right :cheers:
firstly strutto...low voltage can do weird things to the way a computer runs.
secondly a injector doesnt need to have a full 14.4 volts to operate properly
thirdly poor spark and overfueling ......well the fuel just extinguiishes the flame....cause the.....well it just does , hence the misfiring and such.
fourthly i think andrew will find that if he turn all accessories off the car will run better(cause of the low volt deal)
    • Why are people so insistent on making dirty water?!
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
