Poor 32. Lucky it broke down where we were. Otherwise I think we could have been in the shit :P
Thanks HEAPS to Melv for coming and rescuing us! :hugs:
And thanks HEAPS to Mick for following us home to make sure that we made it :(
hahahahahaha yeah melv had just a little prob finding us lol
Ah I Can See You Just Can't Get To You lmao :looney: round & round we go that place was a maze :spcartman
no probs erin any time :angel: I know any of the gys would do the same for me :grouphug:
just a quick update.. turns out to be loose wiring, so thats easy fix.. now just need to wait for ecu tuning. :P
oh and honda city is cool! bring on the city turbo I say! :D
hahahaha there is a soft top turbo up the coast for sale 85 modle for 6k :looney:
that would be cool but thats just a crazy price :bonk: little 1000 lt rocks :(
I know why my car is so fuely ... Well, even more fuely and gutless than normal :(
Alternator is shagged. 12v maximum during running, and 11.buggerall volts once you turn lights on.
If you just turn the lights on, the voltage drops from 12.buggerall to 10.something fairly quickly... Is that a battery problem? Or is the battery only partially charged cause the alternator isnt doing anything? Even with revs (2500-3000rpm) it wont charge the battery at all, just holds a constant 12.3'ish volts.
Piece of crap. I'm with will :P Gimme the little buzzbox back :D
Glad to hear it's only something small Will.
I might ring Gav and ask him why he didn't answer my phone call at 11pm last night.
LoL, other than the sleep thing and all :(
Good to hear it was only a loose wire tho. I think, does that mean your not stripping it anymore? :P
if the alternator belt isn't slipping or overtightening, and measured idle voltage at alternator/battery not showing 13+ volts then alternator is gooooooonnnnnnneeeeeee. :(
dave you can still strip my ful sik subwoofa tape deck?! :(
hmm so does that mean next time I got pick up my pos 32 it'll sport a sohc head with a ded commie battery and sits on bricks? :D:( godamn bogans! :P
RB26ETT for Willis :D
Who needs to D(ouble overhead cams)?
Hmm... RB26 head on RB30 block....
Oh well, I'm sorta glad there is something fairly big wrong in a way... It makes a good excuse for the lousy performance and huge amounts of fuel smoke :D "Oh yeah mate, normally I got 800hp but damn alternator was shagged so I only had 100hp" :P
Now I'm not a mechanic... (Unlike some :S ) But I'm gunna disagree on this one...
Cause... The spark doesn't burn the fuel... The spark starts the fuel burning (I thought) and then the flame front ignites the rest of the charge...
So, tiny spark may not be perfect, but it will either ignite, or miss... Not just burn some of the fuel and spit the rest out...
Also, with low voltage, the injectors wouldn't be opening up as much anyway, so there would be less fuel than usual... (depending on ECU (the car does have EFI doesn't it Andrew :cheers:))
I'm guessing timing and / or fuel pressure and / or tune...
/awaits proof of my stupidity...
Dunno the technical side of it, but with Brutis2, when the alternator died and started giving low voltage he would run REAL fuely.
Then as the voltage dropped lower, he would misfire. Finally, car died totally.
Either way, the alternator is shagged. 12.2v at big rpm in neutral with no lights etc on isnt right. And 11.7v with the lights on also isnt right :cheers:
firstly strutto...low voltage can do weird things to the way a computer runs.
secondly a injector doesnt need to have a full 14.4 volts to operate properly
thirdly poor spark and overfueling ......well the fuel just extinguiishes the flame....cause the.....well it just does , hence the misfiring and such.
fourthly i think andrew will find that if he turn all accessories off the car will run better(cause of the low volt deal)
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
