Genuine Nippon Denso intank fuel pump kit
280 litres / hour - 110 psi
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...item=2493874720
i just get a fuel pump from ebay...can anyone give me a guide how to change it? Better with some pics...hehe...And where can i get the fuel pump filter in Hobart? Is there any thread that guide ppl to undo the dashboard out with pic for manual R33 GTST? I'm going to spray the dash...coz all the rubber drop off......And anyone can tell me where can i get a cheaper alarm and immobilizer installation in Hobart?
i just install a bleed valve to get 0.8bar....the guy told me premium unleaded fuel....only can get up to .8bar...more than will damage ur engine...is not good...and i have blitz POD filter and 3inch turbo back exhaust..next week will change the dump and front pipe and cat to 3inches...then follow by FMIC....
Just wonder like these modi....is apexi SAFC II suit or power FC better? I'm not going to change the turbo...will be using stock turbo...can AVC-R set my fuel map(like SAFC)?
https://www.sau.com.au/forums/topic/53567-some-ques/
Too many questions in one post, I'll answer two and leave some for others...
The Power FC is the go, you have done enough mods to justify it. You should get around 20 rwkw increase in average power with your mods, nicer running and better fuel economy.
My rule of thumb for a standard turbo is 10psi (0.7 bar), anymore than that and you risk ceramic turbine in the cat disease.
over to others.........:P
https://www.sau.com.au/forums/topic/53567-some-ques/#findComment-1051035
To change the fuel pump its pretty straight foward.
***Disconect Battery First***
It's located in the boot next to the battery and below HICAS ecu. you'll have to take the metal cover off and their should be a round black lid like a cookie jar lid. Take the hoses off (They can be very tight) you need to use a lock ring wrench to remove the lock. (black lid) as its very tight. Once you take that off lift the lid up and remove the fuel line and the plug connecting to the underside of the lid.
Then remove the fuel pump buy pulling upwards and remove the fuel level guage - as its connected to the fuel pump. But once its out you can disconect the connect that joins it to the guage and the pump.
Then to put the pump back in, Same procedure just opposite way.
When putting the pump back in their should be little brackets inside the tank you have to mount the fuel pump on it so the sock on the end is in to deepest part of the tank.
The torqe settings for the lock ring (black lid) are:
30 - 35 N-m or 3.1 ~ 3.6 kg-m
Their should be 3 little lines to the top right of the fuel pump on the body of the car.
You have to line that up with the mark on the lock ring.
When you put the metal cover back on the arrow on top should be facing towards the front of the car.
hope that helps,
:P
Jun
https://www.sau.com.au/forums/topic/53567-some-ques/#findComment-1051100
hope that helps,
:P
Jun
Thankx....but i dont have that much tools...is it the spanar enough to open it?
https://www.sau.com.au/forums/topic/53567-some-ques/#findComment-1051613
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
