Hey all
Have alot of standard + Performance parts i dont need:
Here we go::::::::::
- GTR CRANK $350ono SOLD
-GTR CONRODS $350ono SOLD
- GTR PISTONS $250
-GTR OIL PUMP $150ono
-GTR WATER PUMP $50firm
-GTR R33 AFTERMARKET USED 500hp Clutch
Used only 20-25km's... As new plenty of meat left...Single plate, Ceramic...Use is like a brass button clutch...Bought from ADVAN MAKE OFFER$$$$$
-GTR R32 USED OS GIKEN Clutch,
Came out due to engine build etc...Although i noticed slipping in 3rd/4th gears on a 400kw@Wheels GTR..may need rebuild Make OFFER$$$$$
-Trust T88-34D $1800
Travelled 1000km's in Japan...Polished Compressor housing...No surface rust in rear housing like used ones get....
-PAR BILLET CONRODS (RB26)
BRAND NEW In box....PAID $1850 will sell for $1650
More info can be seen at : www.par-engineering.com
-ARIAS PISTONS + Ring Kit (RB26)
BRAND NEW IN BOX..Paid $1550 will sell for $1350
Bore size is 86.5mm...Detailed Specs can be giving if interested...
-STANDARD GTR INJECTORS $400 Travelled 30,000km's SOLD
- Auto Staff Up pipes $300firm
Twin 2 1/2'' pipes into a 3'' Pipe before the cat...
-Blitz Pod filter $200
-Nismo Fuel Press Reg $100ono SOLD
-Standard gtr r33 BOV (30,000km's) $180firm SOLD
contact me via PM or in the thread.....
PARTS NEED TO GO SO MAKE OFFERS
https://www.sau.com.au/forums/topic/53576-gtr-crankrodspistonsclutchsetc-etc/
500HP clutch for the GTR R33 Comes with the flywheel...In its condition i would be looking for around $650ono
OS GIKEN is a twin plate clutch and will bolt straight onto your gtr r32...Comes with the matching fly wheel...I must tell you clutch was slipping on a 400kw@wheels gtr...So the plates may need to be replaced...looking for around $500ono
Let me know
  • 1 month later...
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
