Hey man, are these in the boot ?  Cheers ...
Hi, the one on the wheel arch is outside the car, the other one is in the boot, here's a picture, in the pic on the right the boot is open...
Cheers
  • Replies 202
also, have u got side skirts?
off the top of your head are the sI and sII skirts any different? sII should fit on a sI body though....?
offer a price, pm me your number or call me on 0423736908 or email me at [email protected] to talk bout the skirts and mats.. thanx
Um, sorry, drivers side got smashed up real bad ... can't sell them at all. And $100 for floor mats, sorry, don't think so.
Cheers
um sorry, don't have any of that gear ...
ant95GTR - Yes,  i have the surround for the switches, it will be $50 (series 2 and all).  The console lid will not be sold seperatly however, because I won't be able to sell the rest like that... will sell the whole console for $200.
P1E - Yes, it have the switch and loom - $175
cooky2511 - Not yet man, but will early this week.
skyline33 - sounds good man, I'll have to get back to you tho, someone is digging at the tail lights already ... if it falls through, they're yours ...
whats happening man, are you wanting to sell those parts or what??
can i see a pic of the mats please? wether they've been damaged from wear and tear or not.. plus i dunno what they look like.. if they're good 150 it is.. ive seen a few different types and some of em are a bit dodgy..
and as for the skirts.. im after the left in particular if its not different to a sI which i doubt it would be..
gimme a price on that too please
thanx
Interested in part of the window winding mechanism. At the bottom there is a ball and socket type arrangement that runs along a track parallel to the ground. I really need one of those little white round things that run inside that track. For a decent price I will take more of the assembly if its too difficult to separate.
babs - Hey man, the mats have sold (as per update on front page) ... i'll get you a photo of the skirt tonite ...
zymotic - Hey mate, you name a price and I'll see if it's resonable :rant:
PM's replied to ...
Hey Bogan I sent you PM but you never got back to me. Yes I will take the surround for $50 and I'll cover the postage (should be around the $10 mark) PM me with your banking details etc.....
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
