  • Replies 381
Im gunna go calder park on friday just to race Ni in his Cefiro.
Good luck mate, I hope your VL is good.....  koj si ti ?
just make sure u dont rock up this weekend as stated in previous posts... friday after :cheers:
Thisss khuunnnttttt.. i took out my tail shaft last nite... haha had a bit of problem with it
so we on for this week or next?
so i know if i shoudl hurry da fark up or not :-)
ahahahaha yeah this week :D
rigga... im hoping for low 13s or high 12s... providing i can get traction i would say thats pretty realistic.
:confused: you mean the ceffy is only a match for my barely modded 33? This is going to be fun :D
Make it next Friday coz I is a poor fark this week :(
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
