Hi,
I'm considering a job in Japan for next year, and wondering what's involved in bringing a car back with me to Australia that I would buy over there?
I'm aware that I'd need to have proof of ownership for 12 months or greater, but I'm unsure of how the process differs from the Low Volume Import scheme. Apart from not needing the same type of compliance as a Low Volume import, what other differences are there?
Would the car need to be registered and used, or could it be bought at the beginning of the year, warehoused, and then import as a private import?
Thanks for any info you can provide.
-wm
https://www.sau.com.au/forums/topic/5394-private-import/
I have heard rumours that if you have owned the car for over 12 months living in Japan it can be bought over as a private import and thus does not have t comply with ADR's as not part of the low volume import category.
This would be quite cool indeed.
:uh-huh:
https://www.sau.com.au/forums/topic/5394-private-import/#findComment-82377
Guest GR33DyMANGO
so BY BY you're saying u dont have to pay for compliance with costs a few grand and is increasing in march 2003 to something rediculous so its too costly to import???
that would be so awesome if thats what u mean. i might be heading off to hong kong in about a year to work. hmmm.. maybe i could have an r35 in a few years... hehee....
https://www.sau.com.au/forums/topic/5394-private-import/#findComment-82398
to be eligible for personal import you need to supply the following..... Parking permit,registration documents in your name,Insurance documents,passport(stating that you have been in a particular country for over 12mnths).Once an impot approval has been issued,you can send the car.Once it arrives the car will need to be checked by an engineer.Seatbelts will need to be changed if they dont have an e marking,child restraints be fitted,unleaded filler neck and some other stuff depending on the model of the vehicle.In regards to a car from hk...id forget about it as the tax payable on buying a car and owning it for a year in hk would out way the cost of just buying it straight from japan...especially a model such as a new 2 door skyline which will be eligible under the new sevs scheme anyway.....hope this helps
https://www.sau.com.au/forums/topic/5394-private-import/#findComment-82457
yep....the same duty applies...although i beleive there is a depreciation form that you can fill out but its not woth the hassle...unless you owned the car for 5 years..then the purchase price would be dearer than the current market price.I got pics but how do you post them to apare on the screen and not as an attachement???
https://www.sau.com.au/forums/topic/5394-private-import/#findComment-82501
Yo Waxman, I'm considering going to Japan next year aswell.....
You gonna be teaching english over there or doing something else?
Keep us all informed of how everything pans out for you.......I'm sure that if you go over you'll have no spare time because you'll be too busy finding cheap parts for everyone here! :lol:
https://www.sau.com.au/forums/topic/5394-private-import/#findComment-82551
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
