Doesn't it look insane? :P
The rims are quite wide (maybe 10 inch or so) but they use narrow tyres on them to get that stretched look... with some of the more extreme wheel width and tyre "narrowness" combo's they need inner tubes to keep the tyres inflated. The second last pic is a REALLY good example!
Of course all this came about because "Yanki" (Japanese car freaks) try and outdo each other in car modifying. They have legit "gangs", and having those insane modifications are part of being in the gang... the leader often has the wildest car. Not sure why the use mid-80's Soarers and Mark II's as their choice of car though...
Huhhhh :spcartman... those crazy japs, you also see the most WILD vans with the most ridiculous body kits & wings & stuff... crazzzzzzzzyy
Also how the hell do they drive those cars, they seem to have the lowest modded cars in Japan, super low! The ones with the cars resting on the tires have hyrdrolics right.
Spoilers under the car... they just dont know when to stop do they....:P
No speedhumps in Japan. They really are that low, all the time.
One of these would make a fun daily hack. Anyone got a spare Datsun 240K for sale? :)
Ok no speed humps, but they still have gutters & car park inclines.... theres no way some of those are like that all the time, as the picture shows atleast one of those is resting on the tire.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
