just wondering if anyones knows the answers to a few of my questions...
all questions are related to a rb20 computer...
do they have speed limiters?if so what are they?
when cutting the speed sender wires at the back of the ecu... does it effect anything else?
i know it has rpm limiter, but what is it?
what is the boost cut set at?
what is the max. boost you can run (SAFELY) with stock internals,fmic and exhaust?
does anyone know the most power you can get with these mods?
cheers
https://www.sau.com.au/forums/topic/54125-rb20-questions/
well i know you have a rev limiter at 7000 - 8000rpm
i dont think you have a speed limiter coz ive been off my clock and nearly hit the button thing
i dunno what the boost cut is set at... ive got a T04 and im running 15 psi with a stock intercooler...
i wanna get a bigger FM n try run 20 -25
https://www.sau.com.au/forums/topic/54125-rb20-questions/#findComment-1060614
limited to 180kmh, I know you can cut the wire although not sure which one it is on the cefiro may be different.
rev limiter @7600
not sure on boost cut mayny 14psi, I think most people will agree that its more your standard turbo going to crap itself if you run much more than 14psi through it as its got a ceramic exhaust turbine which is fragile. but speak to people and see what they say. I think for $3000, you can almost get away with a new turbo and ecu remapped which will better your chances at running more boost and up your power a heck of a lot.
but not everyones got $3k to blow in one hit.
https://www.sau.com.au/forums/topic/54125-rb20-questions/#findComment-1060715
VLRB20:
Im assuming rb20 computer hasnt been remapped etc.
1. Yes they do have rev limiters. On mine its 7300-7500 revs.
2. Speed limit is alo rectriced to 180km/h on standard rb20's
3. Its wire #53 on the ECU harness to disable the 180 kph speed cut. It also disables the hicas. Whihc most guys disable anywayz.
4. With stock internals,fmic and exhaust(im assuming trubo bacj exhaust here) i would be running only 1bar max.. even that. Try and get it dynoed tuned b4 trying this thou. 40 bux compared to a new engine/turbo
5. Ive seen my mates on with same mods get 134rkw (dismell numbers i know)on 1bar boost. Soory man but its a sad fact of life with the rb20
https://www.sau.com.au/forums/topic/54125-rb20-questions/#findComment-1060756
I dont think the rb20 is bad at all, I have a few mods on my car and have taken out ss commodores, modified wrx etc, I have a fmic, 3in from turbo, hks2535, boost running about 1.2bar on a tuned rom. I would say you are half the way there just need turbo and tune. should be able to make around 200+rwkw. thats nothing to smirk at.
I recon you can tune your car with your mods for around 160rwkw, if you up the boost. thats around 220kw at the flywheel, pushing a car weighing around 1360kg is not to bad. power to weight of 6.1 kg/kw. you are going to be competitive against most cars you will run against, such as ss commodore, xr6, etc.
its definitley worth getting a run on a dyno if you can and see how you go but as ceffo said no more than 14psi seems to be the general concencus of the limit of your turbo.
https://www.sau.com.au/forums/topic/54125-rb20-questions/#findComment-1060822
For 160-165rwkw, which is the absolute maximum you are going to get with the stock turbo you will need a full exhaust, pod filter, front mount, some kind of boost controller or hks actuator and run no more than 13psi as the stock turbo is at the edge of it's efficiency at this point and only makes heat after that and so the engine likes to ping and thats about it. And i ran about 16 degrees base timing. Pretty easy really. But expect your turbo to die quite quickly at these power levels. Mine actually died at after about 6 months on 12psi.
Stock fuel pump is fine at this sort of power, mixtures are fine but a little rich in the midrange though not by much and spot on at the top end (or atleast mine were at 163). AFM is maxing out at this level, injectors are generally running pretty hard with the stock pump too. for more power you need a turbo and management.
My car had no boost cut.
Cutting the speed sensor wire will effect the speed sensative steering as well and bugger up the automatic box's shifting if you have one.
https://www.sau.com.au/forums/topic/54125-rb20-questions/#findComment-1061565
I'll agree with Dave on that one. I had my boost on 13-14psi, now its back on 12-13psi and feels heaps better. Im still running the stock cooler tho. And I got 142rwkw with that set up, but Im still running a stock dump pipe.
https://www.sau.com.au/forums/topic/54125-rb20-questions/#findComment-1061577
god daveo that's a big figure for stock turbo.. should be nice in the cef!
As for speed cut I don't think the VL would have speed cut as it's aussie vehicle? I mean I've never owned a rb20 or commo but I don't see why it would have one (it's not an import).
My boost is currently about 13-14 and I think its slow (i'm getting used to it).. i'm starting to want a bigger setup.. sigh this is bad.
https://www.sau.com.au/forums/topic/54125-rb20-questions/#findComment-1061788
as stated dont run anywhere near 1 bar boost on a stock turbo with no retune unless u like seeing what happens to an engine when it leans out
i thought id have a little fun one night and upped the boost to 16psi lol
soon as i hit around 5000rpm *blat blat blat blat* lol
straight back down to 13psi :D
https://www.sau.com.au/forums/topic/54125-rb20-questions/#findComment-1062020
Ah conversion. I thought it was a factory rb20 - oops that ain't possible.
Not unless he was lucky and got a prodotype Vl with an RB20 in it :D
But yeah, Im also running a RRFR (riseing rate fuel reg) so Im not overly worried about leaning out, just my fuel bill :D
https://www.sau.com.au/forums/topic/54125-rb20-questions/#findComment-1063210
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
