Installed my REV.EL dials tonight at my brothers house (coz he has a garage with lights)
All seemed to go well until i tried to drive home. About a minute down the road the hicas light comes on and the steering becomes very heavy.
We've got no idea wtf the problem is! The only thing we can think of is that we've unplugged something behind the centre console and not plugged it back in.
The only thing we can see is a plug similar to the hazard light and dimister switch plugs that seems to have no where to go.
Does anyone know what the prob could be?
https://www.sau.com.au/forums/topic/54181-help-with-hicas/
Hicas Diagnostics returned a series of short flashes. pause, 2 long flashes. 1 short, pause. repeat. Which if am reading it right means
error code 21 - Speed sensor not hooked up.
Well i've taken the consol apart and had a look nothing seems to be amiss. The speedo still reads accuratly, and my turbo timer which is also hooked up to the consol can read the speed. So I have no idea whats wrong here? does anyone have any ideas?
https://www.sau.com.au/forums/topic/54181-help-with-hicas/#findComment-1061928
hey rory um just a though u checked the fluid level float I had a HR31 that the float level use to get stuck down & make the light come on just as though as for the hub/wheel speed sensor did u jack the car up or any thing?
https://www.sau.com.au/forums/topic/54181-help-with-hicas/#findComment-1061936
Never mind, I figured it all out...problem solved. Turned out the washer on my Turbo Timer tap into the consol did not have a good connection and was screwing everything up. Anyways now that error code is logged in the HICAS Diagnostics, so it will report that code everytime I run a diagnostics... So how do I reset it? do I have reset the ECU?
https://www.sau.com.au/forums/topic/54181-help-with-hicas/#findComment-1062597
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
