im looking into getting an apexi power fc and commander for my r33 gtst. Just wondereing if any one could give me some tips on what else I should be doing if I install it. (ie- air flow meter, tuning etc)
also an estimate on the price for this system and some links to some suppliers would be great.
:werd:
https://www.sau.com.au/forums/topic/54302-upgrading-to-power-fc-need-advise/
I have a Power FC in my r33 GTR w/ hand controller. It's just a plug and play system. No additional wiring has to be done. In my Opinion they are a top choice. The Power FC is about 1500, the hand controller about 600. Noting has too be changed (e.g Airflow meters).
Something that i think is also great is the boost controler for it. it can be adjusted with the hand controller and ur boost lever can be moitored with the hand con/. Like Gav said its best if the Power FC is installed and Dyno d as son as posible.
http://www.apexi.com.au/
UAS have some prices
Thanx for the responses.
I have managed to track one down for $1300 (brand new with 12 month warranty) with commander- it is in english format and ready to be shipped. Is this a good deal?
I found it through an advertisement in SAU - here is the site for anyone that is interested.
www.JapaneseImportParts.com
Has any one heard of these guys? Are they reputable?
Does this mean i wouldnt need a boost control or boost gauge?
Do I need anything else apart from the PFC and commander for boosting?
If customs dont get it your fine.
I remember reading on here about 3mths ago that Mr Nengun himself said that replacement ECU's are classed as "(something)" which doesn't incur any import taxes.
dosnt the gtr have different AFM to the gtst? If so, would I have to change my AFM on the gtst(r33)??
Make sure you buy one and quote your make and model of car.
THEY ARE CAR SPECIFIC.
He would have one specifically for the R33 GTR as i have a different one for my R33 GTS-T.
They are NOT interchangable so as long as you order the one for your car, you will be fine. www.nengun.com has been used by heaps of people on these forums, do a search and you will see. Very cheap and comes with warranty.
No offence, but you sound like a bit of a newby (me too) so i wouldn't bother with an electronic boost controller just yet. But hey, if your cashed up, go for it.
My goal at the moment is to have the Power FC installed and tuned with the front mount intercooler, a bleeder-boost-controller set to 11psi and my current exhause mods.
Very common setup. Go for that. Probably very close to the 200 rwkws.
I am aware that they are car specific-thnx.
Yeh - im fairly new to modifying performance cars.
Ive actually got a gtst, bought it about 7 months ago totally stock except for the rims.
mods so far
- turbo back stainless 3" with highflow stainless cat and 4.5" canon
- hks pod filter
- hks sequential BOV
- front strut brace
- ebc bluestuffs(fr & bck)
- timer.
Ive got a front mount ready to go on but I would like to install the power fc and boost control (I beleive when you lift the boost it is recommended to upgrade the head gasket also- is that so?)
and oil catch tank all at the same time as well as tuning. Be good to get the dyno result!
Later on I'll upgrade the turbo, injectors, fuel pump, oil cooler, coil overs, bars/bushes then maybe I'll do the internals.
There's no reason you can't do the front mount straight away.
Grab a bleeder valve fro $100 and do that whenever aswell.
Just make sure you install and tune the FC last, or at least at the same time as everything else.
Because the first time you install it you will be up for a $400-$600 tune, not advised to drive it without it being tuned.
If you LATER install the FC and or Boost ctrl, you will need to get it dyno tuned again.
My Power FC is currently collecting dust under the bed untill i get the front mount done.
Literally! Gotta get my act together :P
mods so far
Do your front/dump pipes before the PowerFC.
Certainly incorrect.
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
